Power door locks
Old 06-07-2008, 03:14 PM
biggator60's Avatar
Power door locks
My power door locks do not work, there is power to the switch, makes noise like it should work but doesnt..any suggestions???
Old 06-08-2008, 12:36 PM
SIXSLUG's Avatar
The switch can corrode if it gets wet often. If you a re around salt air it probably is worse. You can lift the switch out of the ddoor panel w/o having to remove anything. Make a jumper and jump across the contacts to see if this is the problem.
If this isn't the problem it may be the solenoid for the locks or a connection to the actuator. Just my .02
Kurt
nomad65
08-20-2007 06:01 PM
BigK
11-25-2003 03:18 PM
Fillerupsonny
06-04-2003 01:51 PM
perk
04-15-2003 08:35 PM
Quick Reply: Power door locks
