potential tranny issues
Old 09-14-2008, 10:31 AM
gwirehair's Avatar
im doing some upgrades this week and wonder if i should worry about possible problems with my auto tranny because of it? right now my truck has 300hp injectors and an afe cold air. im putting in a slightly bigger turbo and getting a box (most likely an edge ez). my tranny slips from time to time but goes away when i reset the apps. im going to put in a pyro and boost guage as well. should i think about a tranny temp gauge too? any help would be appreciated. thanks.
Old 09-14-2008, 12:13 PM
j-fox's Avatar
A stock trans needs help with stock power. You are on borrowed time.
A valvebody is a good start.
Old 09-17-2008, 08:55 PM
dozer12216's Avatar
Like j-fox indicates. Your trannies life is limited. Bite the bullet and fix before failure. Do a tranny service and adjust KD band if you must. If KD band adjust is past threads on screw, the tranny is gone.
Old 09-17-2008, 09:17 PM
Big Deezul's Avatar
it already slips....lol that puppy is done! get a good rebuild and then swap in a goerend VB and converter and you will be good to go
plessm
07-31-2008 09:24 AM
eng208
03-17-2005 09:34 PM
XTOAK
13
06-28-2004 08:13 PM
apache
01-24-2004 09:08 PM
Quick Reply: potential tranny issues
