Possible MAF or VP-44 Failing?
Old 07-07-2008, 10:48 PM
TurboRacer's Avatar
I've had no codes pop up. I noticed that when I get on the gas my miles per gallon go down to 4 mpg on the digital console display. When I get off the gas after like 10 seconds, it will go back to 99mpg until I get back on the gas again. Could this be a failing MAF Sensor or VP-44? I just put in a New Fass 150-95 lift pump system.
Old 07-08-2008, 03:32 PM
Wild4kst8's Avatar
i think you're looking at the instantaneous MPG... what you are describing is normal (assuming you are getting on the "accelerator"... gas & diesel don't mix)
Old 07-08-2008, 05:46 PM
Number47's Avatar
Our trucks dont use a Mass Air Flow meter we have a speed density system. but to increase fuel econ. clean your MAP sensor regularly
linetrash75
09-23-2005 08:32 PM
Gear Poet
07-25-2005 08:39 PM
Asher
07-19-2005 01:36 PM
swansong04
06-11-2005 12:02 AM
rattle_rattle
09-15-2003 07:19 PM
Quick Reply: Possible MAF or VP-44 Failing?
