Poor Man's Brightbox?
Old 12-05-2011, 07:43 PM
Idaho Guy's Avatar
Has anyone on here successfully jimmy's up an electrical thingy which would accomplish the same thing as a Brightbox? That is, the ability to have both the low beams and high beams on at the same time, without overloading the stock electrical wiring/circuits?
Old 12-05-2011, 08:41 PM
roysleight's Avatar
There is a mod to do that by hooking two wires together down under the steering column. I did it and it worked until I put a relay wiring harness on my lights and then I didn't need it. Not sure which wires they were without researching it. Do some searching and you may find some threads on it still.
Old 12-05-2011, 11:46 PM
nickg's Avatar
your better off doing a relay mod, light output can be improved as much as 40% by doing this, factory wiring is too small as it is,
read thru this link, then dig around on his site you will find lots of valuable light related info
http://www.danielsternlighting.com/t...ys/relays.html
Old 12-06-2011, 10:20 AM
MikeyB's Avatar
Here's a circuit I drew up a while back.
MikeyB
Old 12-06-2011, 10:20 PM
Ackerdiesel's Avatar
Is this for single or dual bulb headlights?
Sent from my iPhone using Tapatalk while not driving
Old 12-07-2011, 06:59 AM
MikeyB's Avatar
The circuit will work for both types.
MikeyB
Old 12-07-2011, 10:08 AM
Ryan
Old 12-07-2011, 12:10 PM
MikeyB's Avatar
What's not shown in the drawing is load resistors tied to the low and high beam at the FCM. Without the load resistors the FCM will trip the lights out indicator and shut down the circuit.
MikeyB
kkime
03-25-2010 11:05 PM
AkitaSumo
50
05-01-2009 07:38 AM
wood_n_soldier
01-15-2004 12:20 AM
Mexstan
12-24-2003 04:23 PM
PADZZ
05-24-2003 09:57 AM
Quick Reply: Poor Man's Brightbox?
