POD's are in, more questions
Put my injectors in today and what a change it made. Much more power than stock, only mods so far are the pod's a ground fuel pin and a bhaf. I hope to get the new turbo,exhaust and 366 spring installed in the next week or so. My question is how much hp could this thing make? I cant find a dyno that will run a truck anywhere in southwest wisconsin and i am curious. Here is the setup: 92 W250 5sp bhaf,garage ground fuel pin,pump bumped 1/8 in,fuel screw in 3 turns,starwheel bottomed,366 spring,pod's,ps62/70 12cm wg,4 1/2in exhaust no muffler, snow stage 2 w/m. I also have all the parts for a home built propane setup, just not sure if i really need it.
350 was my goal 400 would be a treat. Any ideas for a little more, ddp stage 4? I am planing to do a powerstroke ic sometime soon. If i fix the rust holes in the roof would that help .
92smokin blacky
03-19-2010 11:39 AM
BrokeSolid
21
02-03-2009 09:36 AM
