Plug In Engine Block ??
Old Apr 12, 2008 | 10:57 PM
BearKiller's Avatar
Question Plug In Engine Block ??
On the larboard side of the engine, down low, immediately behind the power-steering reservoir, about three-inches forward of the injection-pump bracket, is a hex-headed plug.
What is this hole and could it be used to some benefit ??
Thanks.
Old Apr 13, 2008 | 12:47 AM
dpuckett's Avatar
I think what you're talking about is for the vacuum pump oil supply for the latter style vacuum pumps. Check your wife's 91.5 and you'll see what I mean.
Daniel
Old Apr 13, 2008 | 02:11 AM
BearKiller's Avatar
Daniel
I will take a peak at her's in daylight.
If that be the case, then oil-pressure could also be tapped from there, possibly for one of those toilet-paper filters, or other purposes, right ??
Thanks.
Old Apr 13, 2008 | 08:01 AM
Thanks.
Right. On engines with air compressors that's where they get the compressor oil supply. Not that that's important information, but it makes this post more than 9 characters...
Old Apr 13, 2008 | 09:04 AM
daking's Avatar
were would you put aircomperssor on a 5.9, with the ip in the way and psp in the way doesnt leave very many options
Old Apr 13, 2008 | 09:36 AM
The compressor/ps pump combo goes where the vac/ps pump is now.
Old Apr 13, 2008 | 12:13 PM
bgilbert's Avatar
Belt driven with a bracket that bolts to those 3 bolt holes at the driverside front cylinder head.
Old Apr 13, 2008 | 06:43 PM
marksmith's Avatar
So I could use a hydroboost and get rid of the vacuum pump. (use an electric for the HVAC controls) Then throw a compressor/ps pump combo in there for onboard air?
Old Apr 13, 2008 | 06:44 PM
Yeah, if you can find a setup that clears the frame rail.
Old Apr 13, 2008 | 09:13 PM
1985cucv's Avatar
that is right where i hooked mine up to but i think there is two plugs on that side mine is on the one back towards the firewall more
royta
Nov 25, 2016 11:48 AM
VikingDiesel
Feb 7, 2007 05:15 PM
ctturbodiesel
Dec 13, 2006 09:37 AM
rootan
Feb 17, 2006 09:37 PM
