plenty of power but no smoke!
Old 06-24-2007, 04:00 PM
bimmerboy86's Avatar
i have been tinkerin with the pump on my truck and i have plenty of power now but no black smoke. what do i adjust to get that black cloud that i want. thanks Ed
Old 06-24-2007, 04:52 PM
Cowboy_Customs's Avatar
U havent turned it up enough yet. Keep goin, it'll happen.
Old 06-24-2007, 05:51 PM
gomerpile's Avatar
remove turbo, or remove spring from under the fuel pin,or you can turn the torx screw with a locknut under the the little cap on top all the way down, and turn the starwheel as clockwise as possible
Old 06-24-2007, 10:05 PM
Micaiahfied's Avatar
smoke= unburned/wasted fuel
if you are happy with the power level forget the smoke.
Old 06-24-2007, 10:27 PM
BRUISER's Avatar
I agree I am trying to get rid of my smoke.. power without smoke would be awesome
Old 06-24-2007, 10:33 PM
Muted User
LOGAN's Avatar
take the top off your pump, 4 screws and banjo fitting on the back, and rotate the fuel pin so the notch is to the front and turn the star wheel till it bottoms out and sometimes you can remove the spring that sets on top of the star wheel, also you can run the fuel screw in then back your idle screw out.
blackcloud03
11-13-2009 08:38 AM
JThiessen
16
08-22-2009 02:46 PM
MFEUSAF
05-09-2009 07:33 AM
lezmark7
10-09-2007 05:10 PM
slowmo
01-17-2007 09:42 PM
Quick Reply: plenty of power but no smoke!
