Please help need ideas (electrical)
Old 12-23-2008, 03:03 PM
Mosephus's Avatar
We are getting ready for a trip and I just noticed my parking lights are not working. I know for a fact they were working yesterday Since I towed yesterday.
Here is the problem, I checked the fuse and it was of course blown to smithereens so I replaced it and still nothing. I'm getting 12v at the fuse block 12v on one pin and nothing on the other, but I think that is the way it should be.
Where do I look next?
Old 12-23-2008, 03:31 PM
Mosephus's Avatar
Also, the dash lights do not work. What relay if any would control parking lamps? I checked the trailer lights relay and it does click when I Pull the headlight **** back to the parking light pos. But when I pull the relay out it does not have 12v at any of the pins
Old 12-23-2008, 05:50 PM
Fueling around's Avatar
Check fuse #1 (50A) in the Power Distribution Center (PDC) under the hood.
Old 12-27-2008, 08:32 PM
cmonster's Avatar
I'm not sure of the specifics of the 97, but i have replaced a number of dodge headlight switches as a result of pulling a trailer. Certain years did not have a relay for the marker lights and and too much current was going through the headlight switch when lighting up the trailer. As a fix the burned up switch would be replaced and a relay would be added to the marker light circuit. I'd check your headlight switch directly at the pigtail with a test light. good luck and I hope I was able to help.
Old 01-02-2009, 10:04 PM
Buzz'nhalfdozen's Avatar
cmonster is on the money. just had the same problems with my 97. turned out to be the head light switch
Old 01-02-2009, 10:10 PM
Bluedually4x4's Avatar
Stupid question but do you have a stock radio or aftermarket? I had a similar problem and it was caused by the yellow wire going to the radio shorting out. It is the signal wire to tell the radio to dim when you turn the lights on. That was an expensive dam fix.
eot
13
04-16-2010 10:50 PM
crittergetter
28
06-23-2009 10:44 PM
SuperiorRam
03-15-2007 03:10 AM
NHdodgeman
11-28-2006 05:32 PM
Commatoze
12-22-2002 07:26 PM
Quick Reply: Please help need ideas (electrical)
