please help me with my questions
Old 01-16-2008, 03:54 PM
mitchkim's Avatar
new to this 12 valve forum as i have just sold my 03 and have been in the 3rd gen forums for some time
anyway i am looking at replacing my 03 with a 97 12 valve
i would like some answers to these questions
what is the hp and tq on the 97 12 valve
how much hp will the stock tranny take as far as more power
how do i turn up the power with the fuel plate
does it have a lift pump or injection pump
does the torque converter stall as high as the 3rd gen trucks on take off
does it have a block heater
thanks for the answers to these questions
Old 01-16-2008, 03:57 PM
smokeyram's Avatar
someone else may have some more input, but a few of these i know.
what is the hp and tq on the 97 12 valve stock i think llike 190 hp, 400 tq
how much hp will the stock tranny take as far as more power , double
how do i turn up the power with the fuel plate, slide it up, or replace it
does it have a lift pump or injection pump, i should know, but i dont. both i think.
does the torque converter stall as high as the 3rd gen trucks on take off, havent been in an 03, i would hope the 03 is better.
does it have a block heater,yes
Old 01-16-2008, 05:21 PM
strokerace's Avatar
depends on if you get an auto or a manual tranny, the manuals are 215hp from 96-98, the autos are a little less but not sure how much
auto or manual? The manual trans with a performance clutch will take about as much as you can throw at it. An auto will need some attention if you plan on doing some high hp mods to the truck
search on here about fuel plates and grind one
both
not sure
should have one
Old 01-16-2008, 06:37 PM
TIMMY22's Avatar
Not much, depends how you drive it.
I have 162K on mine now and the TC is getting real loose.
Old 01-16-2008, 07:19 PM
putzer's Avatar
turning up the fuel is all done by getting the wrenches out, nothing plug and play on the 12 valve engines.
auto trans stock hp is 189-190 i believe, standard trans are 215 hp rating stock.
should have a block heater standard.
it has got a mechanical lift pump, camshaft driven drivers side of the truck, about 2/3's back, it has got a plunger on top of it to prime the system.
Injection pump is a bosch p7100 with a rqvk governor. it is a inline pump, extremley durable pump and takes modifications quite nicely.
Old 01-16-2008, 07:37 PM
displacedtexan's Avatar
Our lift pumps are also capable of flowing plenty of fuel for reasonable mods (there are guys with well over double factory power still on stock lift pumps)
They also rarely fail.
DHT
04-02-2010 07:12 AM
SuperiorRam
03-15-2007 03:10 AM
MoparRiggan
01-17-2006 12:43 PM
GreyBoy
22
10-08-2003 09:45 PM
Greenhorn
02-22-2003 07:11 AM
Quick Reply: please help me with my questions
