PLEASE HELP 02 DODGE CTD Starting problems
Old 04-21-2007, 05:28 PM
Texan's Avatar
If my engine is warm and I shut it off it will not start again until the engine cools off. Does any 1 have idea what is wrong. The vehicle is an 02 CTD. PLEASE ANY ADVICE would be great.
Old 04-21-2007, 05:30 PM
starkey's Avatar
Have you tried bumping the starter to see if the lift pump is working? Cycle the key three times and see if it throws any codes.
Old 04-21-2007, 05:34 PM
Texan's Avatar
I tried bumping the key and nothing...the truck just turns over and over and over...but will not crank..if it sits and gets cold it starts back up no problem
Old 04-21-2007, 05:36 PM
starkey's Avatar
So you tried just the quick starter bump and didn't hear the lift pump working? sounds like a dead lift pump
Old 04-21-2007, 06:39 PM
Mike D's Avatar
Pull some codes!
Failing injector pumps have been known to cause this problem.
Old 04-22-2007, 10:23 AM
NoSeeUm's Avatar
If you don't know how on an 02 you can pull codes very easily.
Get a pencil and paper ready
Turn the key on for a second
Turn the key off for a second
Turn the key on and leave it on
Watch in the digital odometer window
Keep watching until you see pDone
Jim
Old 04-22-2007, 10:37 AM
Dr. Evil's Avatar
The ONLY way to make sure you have ALL the codes is to have it scanned with an OBDII code reader.
Hard starts when warm and white smoke when it starts are classic signs of a dead Injector Pump. If thats the case, the codes will be P1688, or P0126. My guess is that both the lift pump AND injector pumps are shot.
Texan, if you dont already have a fuel pressure guage in the cab - its time to get one.
Exekiel69
MDDTR #33
02-24-2009 02:08 PM
Texan
04-21-2007 05:33 PM
SuperiorRam
03-15-2007 03:10 AM
edy
03-25-2006 07:46 PM
Dougs69299
08-21-2004 08:31 PM
Quick Reply: PLEASE HELP 02 DODGE CTD Starting problems
