Placing of egt Probe
Old 01-07-2005, 06:37 PM
ezdemon72's Avatar
Where is the best place to put egt probe for gauge? I.E near a certain cylinder? Also the instructions say to start the engine for a few second to get rid of any metal chips that might have fallen in the exhaust manifold. Won't these hurt the turbo if you don't get them out? Thanks in advance.
Old 01-07-2005, 07:50 PM
Tire Hater
John Rodriguez's Avatar
drill and tap it with the vehicle running.
Old 01-07-2005, 11:46 PM
HighTen's Avatar
Personally, I think the best place is in the vertical section of the exhaust manifold, somewhere above the turbo. Also, I think it is best to put the probe in the hotter half (closer to the cab). That's where I'll be putting mine. I have also seen a picture of the location I'm describing in someone's picture gallery.
Old 01-08-2005, 02:06 AM
Barry Smith's Avatar
What ever you do don't put it dead center of the pipe my dads truck has a nice pipe plug beside his egt probe Who would of thought of them running a solid piece own the middle?
Old 01-08-2005, 09:06 PM
OOPS's Avatar
You mean something like this!!!!
Old 01-09-2005, 06:38 PM
Cummins600's Avatar
I drilled/tapped and then used a mag. to pull out all the shavings.
See photos here (w/comments):
http://mnelson.smugmug.com/gallery/225923
Also note the tools used here are for sale in "My Classified Ads!" area.
Old 01-09-2005, 08:24 PM
J BODY's Avatar
The two I've seen on the CR engines have been just to the right of your missed shot OOPS. I know on the old school 24 like mine most prefered it toward the rear three cylinders as it seems #6 is the cylinder most like to keep an eye on. Prob with that on the new ones is that only two cylinders feed that rear runner.
Old 01-10-2005, 11:36 AM
Agades's Avatar
I am currently running two probes
one in the rear half of the outlet (to turbo) and one at the 3rd cylinder
there is a big difference
the one right at the #3 cylinder gets hotter faster for obvious reasons but I notice heat spikes that the other probe misses completely (about 250* difference)
after holding speed for a few seconds they even out (heat soak temp)
the rear half does run about 50* hotter when holding speed
but the #3 probe catches the max WOT reading for me
I think the ultimate settup would be a probe right outside #5 (thats the one people are cooking) and one right at the turbo (for heat soak temp)
Old 01-10-2005, 11:41 AM
Agades's Avatar
#4,5, &6 feed the rear half
not just two cylinders
Old 01-10-2005, 04:42 PM
bhoeffner's Avatar
Placed mine behind number 3.
Old 01-10-2005, 08:23 PM
JHardwick's Avatar
why would you do that
if you drill and tap with the engine running, the turbo is turning ........... not that a couple of iron chips are gonna hurt it, but
if you drill and tap with the engine off, any iron chips that fall into the exhaust should be blown out before the turbo starts to turn on fire up
beyond that, a couple of small shavings aren't going to hurt a turbo anyway .......... now if you break the end of a drill bit off in there, thats a whole different ball game in a different stadium!!
Old 01-10-2005, 08:29 PM
bhoeffner's Avatar
The idea is that you would build pressure in the manifold, when doing this you should tape over the talepipe to allow pressure to build, thus when you break through the manifold all the chips are blown out and do not fall into the turbo. Be sure to wear safety-goggles those things realy fly.
Old 01-10-2005, 08:39 PM
JHardwick's Avatar
ahhhh, you guys worry too much!
you should talk to some diesel mechanics, those little shavings won't hurt a durn thang!
Old 01-10-2005, 09:52 PM
bhoeffner's Avatar
I agree.
When I did mine I just drilled and tapped it, and used a magnet to remove the big chunks then started her up! The turbo is not spinning at that time anyway it should just blow the shavings down the tail pipe.
Old 01-10-2005, 10:15 PM
Nascarcamper's Avatar
I WOULD SAY SO... lets see 4" tailpipe reduced to 7/16"
Quick Reply: Placing of egt Probe
