Performance ?'s
Old 07-01-2007, 01:35 PM
Copenhagenjunkie's Avatar
Performance ?'s
I am very happy with my current setup EXCEPT I get very hot egts when:
1. Towing 70 mph w/ 8-10k & I have a strong headwind, 1000-1200 degrees.
2. Empty on steep hills @ 80+ mph, 1200-1400 degrees.
The superchips is on tow/safe always.
I know a 4" downipe and a Afe stage 2 will help.
What I was wondering is if I could get by with a larger turbo and not lose the current little lag I have now? The HTT 35/40 doesn't hit until 1700-1800 rpms but then hit's good and it's really nice towing when I want to make a pass. Max boost is 30 psi.
Which HT turbo would be best for me if any?
Thanks.
Old 07-01-2007, 02:40 PM
Mike D's Avatar
Have you thought about adding water to cool egts when towing?
I've had good results with my 64/12, towing and running empty, but I have a bit more fuel than you.
Old 07-02-2007, 04:27 PM
I really didn't want to go down the water path. My truck really pours the black smoke (not lugging) before the boost comes up, then clears right up. Does that mean I need more air or is that just normal turbo lag? I think I will try the 4" downpipe and the afe stage 2 in that order. I had a BHAF w/ shield on last summer and the egt's were higher.
I know the temps I gave are not that bad but if I could knock off a max of 200 deg I would feel better.
Whatcha think.
Old 07-02-2007, 04:40 PM
haloman's Avatar
IMO these two mods will keep your EGT's in check better and help with any future mods.
Old 07-02-2007, 04:53 PM
Ok, I just wanted a second opinion. I will do those two and be done w/ my mods. May be a single stack though.
Thanks.
ladyram
03-22-2003 12:53 PM
Hired Gun
21
03-21-2003 10:35 AM
Mexstan
03-16-2003 09:34 PM
zeik
03-12-2003 04:27 PM
Quick Reply: Performance ?'s
