Pac-Brake
Pac-Brake
Talked to my dealer today and was informed that DC dropped Jacobs for Pac-Brake. Has anyone else heard the same? I know they are both good products. Dealer also said Pac-Brakes were guaranteed for 3yr/100,000 mi..
Bought my truck in Aug and had the dealer install the ex. brake. Apparently they were having issues getting the brakes from Jacobs (back order, malfunctions...I don't know). Anyway, a PAC Brake is what they installed in mine. I don't have the switch on the shifter though. They mounted it on the dash to the left of the steering column. Six of one, half-dozen of the other if you ask me.
Pac Brake
Can you get it for an Auto yet? Wouldn't you have to at least have a TC and VB upgrades to utilize the Pac Brake system? Can you lock it out or open I should say when you don't need the exhaust brake system for around town non-towing application?
Originally posted by mattymac
Mine works awesome!
Mine works awesome!
Nothing like never hitting your brakes! I have to tap my brake just a few times to let others know I am slowing down.
Works GREAT against tailgators
Just got mine installed on the new truck last night. havent towed with it yet but empty, you can sure feel it. There sure are alot of changes with the 05-610 engines/trucks.
They are available for auto's but you need something for tc lockup if you don't then you have to manually down shift get your rpm's up and you won't see all the benefit. Bd power makes a product called the towloc for controlling torque convertor lockup in exhaust brake applications mated together with their pneumatic ram to control line pressure the brake will really work I Drove a truck once that had a Exhaust brake on a auto without any kind of lock up device and it sucked it was test drive at a local dealer
Originally posted by Buzz
What are some of the changes for 2005 besides the 10 h.p....fabricated or not?
We have installed many of the Pac Brakes and they do work very well and the install is clean. Pac also has some options available such as the gear shifter switch, clutch pedal switch and supplemental air tank for extra capacity.
Shilohman
22
11-19-2009 05:13 PM
iflych52
25
10-10-2006 09:25 PM
wvcowhauler
13
04-03-2005 11:39 PM
