Pac Brake - Air Leaking???
Old May 15, 2007 | 11:31 PM
pet05's Avatar
On the Pac Brake PRXB, my air storage tank leaks overnight. It is NOT the tank but most likely somewhere from the compressor. Can one install a check valve?? Has anyone else seen this problem?
Old May 16, 2007 | 07:40 AM
Fisherguy's Avatar
Don't know much about the Pac Brake (yet) but first thing I'd do is soap test all the fittings...
Old May 16, 2007 | 02:21 PM
Festus's Avatar
pet05,
I'll almost guarantee that your leak is from one of your fittings that the plastic airlines is connected to. I have found in the past that if the airline is not cut perfectly straight and held in place while tightening the fitting, it will leak. You'll need new ferules to take them apart and check them - once the ferules are used, they can't be reused - you'll cause a bigger leak by reusing them.
Jmac
Jul 1, 2009 09:15 PM
belltech64
Feb 14, 2009 03:57 PM
Jmac
Oct 29, 2008 01:08 PM
blownsmoke
Jun 9, 2008 09:08 PM
heredia_mike
Feb 5, 2007 09:29 PM
