P7100 question
Old 04-24-2007, 05:42 AM
diesel don's Avatar
P7100 question
I still would like to know what the item is for that has the lock wire and the lead seal on it. I think it is on the screw that is a socket head screw with no place to put the hex wrench. I was told that it is the cold Idle adjustment . When I start up my truck even when it is fairly warm it idle at about 500 RPM but comes up in a short time it did not do this when it had less miles (38,000) on it. Is that where the setting is to change the cold idle?
Old 04-24-2007, 09:09 AM
ratsun's Avatar
I think you are talking about the plug that opens to give access to the governor springs? There is a idle adjustment bolt on the bottom back side under all the linkage.
Old 04-24-2007, 10:18 AM
Dr. Evil's Avatar
diesel don,
Look here: http://www.dodgeram.org/tech/dsl/adj...d_Gen-Idle.htm
Old 04-24-2007, 02:51 PM
DTR's Toad Wrangler
Clayten's Avatar
That is where you go to adjust the governor arm.
HRDROKN
03-10-2007 11:06 PM
pull-do
02-02-2007 06:11 AM
Brendan
12-11-2006 12:26 AM
West Coast
11-07-2006 11:34 PM
storx
74
09-24-2006 02:24 PM
Quick Reply: P7100 question
