P7100 pump
Old 10-23-2003, 10:52 AM
hvanflee's Avatar
P7100 pump
Just wondering if a backyard mechanic like myself can take out and reinstall a P7100 injector pump, or do I need to have a diesel shop do it?
Can the injector pump be worked on by a backyard mechanic?
The reason I ask is I have one cylinder that is not firing. I have checked the injector and the fuel lines. I think my injector pump needs some work. Before I do anything drastic I will have a piston pressure test done.
Thanks,
Howard
Old 10-23-2003, 11:11 AM
DieselDaze's Avatar
Re:P7100 pump
It can probably be taken off and installed by a "BackYard Mechanic".
However, as I understand it, working on the P pumps takes some special equipment to calibrate the internals of the pump.
Rich
Old 10-24-2003, 09:50 AM
MnTom's Avatar
Re:P7100 pump
This is probably going to sound dumb, but did you check the delivery valve on the pump? Is it possible that the pump is functioning like it should? Before I went ahead and pulled the pump I would check everything that I could. The next step I would take is a compression test and see what happens. Is there no fuel getting to the cylinder that is not firing? Once you find that out then you know which direction to go.
Keep us informed
Tom
Old 10-24-2003, 10:14 AM
hvanflee's Avatar
Re:P7100 pump
Rich, thanks for you input.
Good suggestions Tom, after I had the injector checked I had to bleed the hole system, I was getting fuel to all 6 injectors, that does not mean there was enough pressure to pop the injector.
Tell me more about this delivery valve. Is there one for each injector? is it in the injector pump and can I check it myself? Next question is how do I check the delivery valve?
Thanks for your help,
Howard
Old 10-24-2003, 10:23 AM
MnTom's Avatar
Re:P7100 pump
On the top of the pump there are 6 delivery valves. They are the things that are between the actual pump itself and the fuel lines. If I knew how I would post a picture so you cold see them. I think I would try to switch the valve from the dead cylinder with another to eliminate the valve as the culprit. You are supposed to use a special socket to remove them, but a pair of "vicegrips" do work. Just make sure that you keep track of the copper gaskets and such. ABOVE ALL ELSE KEEP IT CLEAN!!! Atleast then you will know if it is the pump or not.
Old 10-24-2003, 10:43 AM
hvanflee's Avatar
Re:P7100 pump
Thanks Tom,
This is a great idea, I know exactly what you are talking about now. If the valve is bad will it deliver fuel to the injector at a low pressure or will it not deliver any fuel?
I will try an switch two valves and see what I get.
I went back and reread the other topic stuff I started in the help section, I now know what you were trying to tell me. I thought you were talking about the injector as the delivery valve. Sometimes I am so dumb
Old 10-24-2003, 10:50 AM
MnTom's Avatar
Re:P7100 pump
Naw, y'ain't dumb............... Just sometimes we get somthin' in our heads that we can't get out . I just went back and reread that you say you are getting fuel to each injector. Would it be possible to pull the injectors and have them tested? Now might be the time to look into upgrading them.
Anyhow, Keep us informed.
Tom
Old 10-24-2003, 10:58 AM
hvanflee's Avatar
Re:P7100 pump
I did have the one injector (#6), on the piston that was not warming up, tested. It tested to be just fine. Would you say that the delivery valve is not the problem if fuel is getting to the injector?
Could fuel be getting to the injector through the return line?
Old 10-24-2003, 11:11 AM
MnTom's Avatar
Re:P7100 pump
Boy. the more I read the more expensive this sounds. I am beginning to think that the fuel system may be fine. Since you had that injector tested and it was ok I guess a compression test is next. I think you may find that you are going to be pulling the head and hopefully that is all you need to do. Is there ANY differant sounds such as a slight intermittant knock? I am beginning to wonder if there isn't something more serious going on. I understand that if the cooling nozzle is plugged or fell out you may not know for a while until you work the engine some and then score a piston or worse. I am not trying to scare you, but I am just throwng ideas at you. If I think of anything else I will let you know.
Tom
Old 10-24-2003, 07:33 PM
Mostwanted's Avatar
Re:P7100 pump
congratulations!!
You upgraded from back yard to shade tree mechanic ;D.
Old 10-24-2003, 07:38 PM
MnTom's Avatar
Re:P7100 pump
Who, me or hvanflee???????????
Old 10-25-2003, 11:59 AM
Mostwanted's Avatar
Re:P7100 pump
hvanflee
Old 10-25-2003, 10:07 PM
Muted User
Superduty12v's Avatar
Re:P7100 pump
The delivery valve is a one-way check valve. If it is not working then the inj pump will pump the diesel up through the injector line but it will come right back down with the plunger if the vavle doesn't shut. so your pump could be fine as well as your injcr's.
Old 10-26-2003, 09:22 PM
98rammer's Avatar
Re:P7100 pump
yes, you can do it in your yard...i put my marine pump on in my yard (it even sprinkled here and there).
yep, the delivery valve helps to control the fuel "waves" inside the fuel lines to prevent secondary/unwated injections from a "wave" going back to the injector (nozzle really) and injecting more fuel.
Tom
Old 10-27-2003, 12:21 AM
Extreme Diesel's Avatar
Re:P7100 pump
I have taken my pump on/off a couple of times. Make sure you get the tools to time it though.
td3620
05-06-2011 01:29 PM
masonic-dodge
21
12-03-2005 01:10 PM
leprechaun
09-05-2005 11:51 AM
mr T
0
02-05-2005 10:35 PM
jimrob
02-27-2003 12:33 PM
Quick Reply: P7100 pump
