p7100 pump removal
Old 12-27-2007, 06:29 PM
12 valver's Avatar
p7100 pump removal
What is the easiest way to take this pump out, without screwing up the timing?
Old 12-27-2007, 06:49 PM
piers harry's Avatar
set the engine to TDC, then make sure the pump you put back on is pinned to the timing you want.....don't forget to unpin the pump before turning motor over
Old 12-27-2007, 06:52 PM
logskidder's Avatar
You dont need to worry about it when you remove, when you go to reinstall you need to use the timing pin on the gear cover and the side of your pump. Its pretty easy. I or someone else can walk you through it when you get that far. Junk one out or swapping for a upgrade???
Old 12-27-2007, 08:35 PM
12 valver's Avatar
yes this pump is junk!#5 on the injection pump stopped working and siezed the rack from moving. I'm looking for a 215 pump!
Old 12-27-2007, 08:55 PM
logskidder's Avatar
A 180 would also be a nice if you cant find a 215.
Old 12-28-2007, 02:22 AM
12 valver's Avatar
would a 180 work good with a manual trany? or should i just look for a 215?
td3620
05-06-2011 01:29 PM
gator_grabber
02-03-2011 11:48 AM
apache
07-31-2005 07:44 PM
Txwelder
03-08-2005 07:12 PM
jimrob
02-27-2003 12:33 PM
Quick Reply: p7100 pump removal
