P7100 Fuel In The Crankcase???
Old 01-11-2008, 05:51 PM
TOMTOM's Avatar
Any clue where to start? got about 3" extra of oil level on the stick. Smells like diesel.
TOMMY
Old 01-11-2008, 06:10 PM
dieselman2300's Avatar
A stuck (not firing) Injector will cause that.
Old 01-11-2008, 06:26 PM
Tate's Avatar
Pump could be leaking internally, as could the lift pump. Does the truck have a miss to it? How's the fuel pressure?
Old 01-11-2008, 06:43 PM
TOMTOM's Avatar
Idles smooth, fuel pressure was 20psi at idle. my lift pump was leaking from the weep hole so i removed it and used my frame mounted electric pump 15psi. Not sure if the fuel may have leaked into engine before i removed the lift pump, didn't check it till today.
THANKS: TOMMY
Old 01-11-2008, 06:47 PM
Tate's Avatar
Drain the oil, and monitor accordingly. I'd suspect you'd have a good miss with a bad injector, and possibly with the IP leaking as well.
Old 01-11-2008, 06:53 PM
TOMTOM's Avatar
Sounds like a plan. Will keep yall updated.
thanks----- TOMMY
Old 01-12-2008, 04:31 PM
TOMTOM's Avatar
Well: drained the oil, refilled to the bottom mark, drove it 6 miles now it's on the top mark. Guess it's time to look for a good pump shop.
TOMMY
Break Away
06-24-2007 09:00 PM
OOPS
09-14-2006 11:58 PM
BigBRUNO4
09-09-2006 06:30 PM
offshore80
06-07-2006 10:15 PM
rattle_rattle
06-21-2003 12:02 AM
Quick Reply: P7100 Fuel In The Crankcase???
