P1690 code
Old Oct 26, 2005 | 10:34 AM
Tim F's Avatar
P1690 code
Got a check engine lite over the weekend.Was towing the trailer.Felt like it was down on power then clear up,comes and goes.Scanned it and has a 1690 code.Any ideas what will set this?Will the lift pump going out set this?Have to check the fuel pressure yet.Will a speed sensor cause this code.The truck has had a problem with the cruize staying set sense i got it couple months ago.Dont know if this is related to the code setting.Cruize Will set then loose it,reset and will work then loose it again.Didn't see a speed sensor code.Just looking for some imput from you guys.Trucks a 01 H.O.6spd.Had a 91,have to learn this one.Thanks........Tim
Old Oct 26, 2005 | 07:12 PM
phox_mulder's Avatar
Well, here's the code definition.
P1690 Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor
Crank/cam position sensor going bad?
phox
Old Jul 14, 2016 | 03:50 PM
Wadestone1255's Avatar
2001 dodge 3500 diesel 6 speed
Last night my truck started throwing p1690 code loss of power everything else works just fine any suggestions I'm lost good fuel pressure
Old Jul 15, 2016 | 10:51 AM
Greg Reed's Avatar
Replace the cam position sensor. Geno's or Cummins have them. It is kind of a pain to get at, behind the VP44. I don't believe the 2001 has a crank position sensor. I had one go out on my 2002. Eventually started throwing 0216 code. Luckily at that time was covered by warranty.
Old Jul 20, 2016 | 02:34 PM
I tried that and still same thing loss of power check engine light on with same code I did notice a slight smoke coming out at idle I'm thinking pump problem
LUKE-MM-PULLER
Sep 29, 2013 12:51 PM
rokrawlr
Sep 3, 2010 03:50 PM
Timberman
Jan 20, 2008 07:44 PM
daystar
Feb 25, 2004 02:57 PM
WLDuBard
Feb 18, 2004 07:26 PM
