p1689 no comm from ecm to inj pump.
Old 08-22-2008, 10:48 AM
rigsy340's Avatar
hey guys anyone come across po1689? this truck is intermittently cuting out, new transfer pump and filter, wiggled harness, truck running fine now, seems to happen mostly when passing on the highway. i think its the pump module, any info out there
Old 08-22-2008, 06:56 PM
leeboy's Avatar
Hey Bud, take a look at my thread https://www.dieseltruckresource.com/...d.php?t=213458
I changed my Crank case sensor and everything went away.....
Old 08-22-2008, 07:04 PM
dieselfan's Avatar
i got the 1689 when my pump died.
the guy that fixed my truck said the wire that controlled the vp from the ecm was brunt and he had to piggyback it. he new wiring hardness was $800
Old 08-22-2008, 11:51 PM
RacerRon's Avatar
A failing Edge EZ or Comp can also cause this code. I found out the hard way (changed VP44). Try to unplug the Edge data port connector, clear the codes and drive for a bit. If that cures it, call Edge....they are very good about fixing the boxes even if out of warrenty.
When my crank sensor was dieing, my tach would drop to zero momentarily, engine would stumble, AC compressor would disengage, and alternator would stop charging. But, mine is a 2000 model and has only crank sensor....I think your truck also uses cam sensor for the engine running signal to the ECM. So, your symptoms may vary a bit.
Old 08-23-2008, 08:31 AM
rigsy340's Avatar
this is my buddys truck, completely stock, p1689 is the only code.
Old 08-23-2008, 08:51 AM
dieselfan's Avatar
mine was pretty much stock when it died.
Old 08-23-2008, 04:55 PM
dozer12216's Avatar
I swore Leeboy had a dying IP. Fortunatelly he tried sensor due to cost and he saved a bundle. Good for him. He also had the crank sensor code in addition.Hope you can be so lucky, cause it is normal classic case for early VP44 failure. Look carefully at wiring for damage also. Good luck.
Old 08-24-2008, 12:38 PM
leeboy's Avatar
Without you guys and this forum, i would have spent alot of money i didnt have.....Still waiting on my pressure gauge....Just to be sure its up to snuff....You guys Rock!
Old 10-02-2008, 02:57 PM
REDNECK-WELDING's Avatar
hey i just had this problem.. well i still do as the truck in the shop... i just had the injection pump and lift pump done with the cam senser 2months ago... and i got the p1689 a few weeks ago and it was my injection pump.. so im waiting on warrenty.. it had to do with the electrical in the injection pump... also im in kamloops too
Old 10-02-2008, 07:31 PM
johnh's Avatar
'01 does not have a crank sensor
Timmay2
01-05-2020 04:54 PM
Mike D
NCDTR #18
03-17-2009 08:16 AM
Mike D
NCDTR #18
03-09-2009 07:42 AM
9 sec camaro
20
08-26-2006 01:30 PM
Haulin_in_Dixie
47
11-17-2002 09:30 PM
Quick Reply: p1689 no comm from ecm to inj pump.
