P0720 code
Old 07-27-2007, 05:10 PM
vj_M's Avatar
P0720 code
I keep getting this code and the tranny won't take anymore fuel in first gear then if you let it coast it will work fine again and will shift.. this only happens after the truck is shut off...
P0720 OUTPUT SPEED SENSOR MALFUNCTION
when i clear it it won't do it before i pull away then it comes back..
what do I do any answers.?
and what caused it.?
thanks VJ
Old 07-27-2007, 06:32 PM
53 willys's Avatar
SYMPTOM
P0720-LOW OUTPUT SPEED SENSOR - RPM ABOVE 15 MPH
WHEN MONITORED
Continuously with the ignition on, engine running, and gear selector NOT in park or neutral.
SET CONDITION
This DTC will set if the vehicle speed (reported from the CAB module) is above 24 Km/h (15 MPH) , and the monitored Output Shaft Speed is below 60 RPM for 2.6 seconds .
POSSIBLE CAUSES
  • Park/neutral DTC present
  • Intermittent wiring and connectors
  • Output speed sensor ground circuit open
  • Output speed sensor signal circuit open
  • Output speed sensor ground circuit shorted to other circuits
  • Output speed sensor signal circuit short to ground
  • Output speed sensor signal circuit shorted to other circuits
  • Output speed sensor ground circuit short to voltage
  • Output speed sensor signal circuit short to voltage
  • ECM
if this is the ONLY code you have, I would say check the wiring at the speed sensor if it looks ok then I bet it it your speed sensor......I think they are under $30 bucks either way???
good luck
Old 07-27-2007, 06:45 PM
vj_M's Avatar
So start by cleaning up the connection..? I will do that right now...
Old 07-27-2007, 06:51 PM
53 willys's Avatar
yes and looking for any broken connections or wires
dielectric grease cant/wound not hurt either...
Old 07-27-2007, 06:56 PM
vj_M's Avatar
ok just looked and its broken off right half of the sensor is in the tranny and the wire is just hanging there so i need a new sensor.. when I call NAPA whats the name of the part.. and are all the dodge ones the same.?
Old 07-27-2007, 07:00 PM
DTR's 'Go to Guy'
vzdude's Avatar
Same sensor Dodge and Chryler have used since 89! Should be around 20 - 30 like ****** said. O.E.M. part number is 4800879. Dodge calls it an output speed sensor.
Old 07-27-2007, 07:46 PM
vj_M's Avatar
Just picked er up 53.00$
Old 07-27-2007, 07:58 PM
DTR's 'Go to Guy'
vzdude's Avatar
ouch! List price from Dodge is 20.95. Someone needs a butt whoopin! That is robery. At least you can fix it I guess.
Old 07-27-2007, 10:32 PM
53 willys's Avatar
sometimes the dealer is cheaper for parts believe it or not!!!
glad you found the problem
Old 07-28-2007, 03:53 AM
vj_M's Avatar
that price is Canadian..what ever tho its still cheaper then buying a new transmission.
Old 07-28-2007, 11:49 AM
DTR's 'Go to Guy'
vzdude's Avatar
Canadian! That could be a big difference. I don't know anything about the conversion rate. But probably a lot closer to being priced right than it originally sounded.
Old 07-28-2007, 11:58 AM
Festus's Avatar
Nah, our prices get stupid as soon as goods cross our borders. Sometimes double of what you guys can get stuff down there even though the dollar exchange is very close. This is why I order most of my stuff from your side of the border - even with shipping and brokerage fees, it's still usually cheaper.
Old 07-28-2007, 12:20 PM
vj_M's Avatar
When i go to change this out is there gonna be fuild comming out ..? If so alot.?
Old 07-28-2007, 12:25 PM
DTR's 'Go to Guy'
vzdude's Avatar
Less than a half quart or so. Sometimes none if it has sat long enough and not on a hill. Be ready for some though.
Old 07-28-2007, 01:08 PM
vj_M's Avatar
how long would it have to sit for..? a few hours..? over night..? its been sitting now for about 10 hours..
Quick Reply: P0720 code
