p0341 code and Smarty not working
Do you guys know if the p0341(cam sensor code) will cause the Smarty to not work or the ecm to go into a fuel saver mode. I have that code on my conversion and when I load the Smarty file there is no change in the power of the truck. Also have a surging problem. I am going to check the wires to the ac compressor tomorrow and if they are good. I will change the sensor.
Check out this thread.
https://www.dieseltruckresource.com/...ght=cam+sensor
I use to get that code about once a week. I finally got to the wires by the A/C compressor and unwrapped them. I didn't find any chafed all the way through but then rewrapped and put wire loom on those wires and the problem went away.
Steve V.
11-30-2008 03:10 AM
