P0261
Old 04-19-2007, 05:11 PM
darrenw's Avatar
P0261
I was driving along and it cut out and the guage went down to 10 psi. After I got home I replaced the fuel filter and it is now back to 16 psi. Code was P0261 on the superchip which is installed on the tow mode. Does anybody know what this code is? Thanks!
Old 04-19-2007, 06:14 PM
darrenw's Avatar
Does this mean my injector pump is shot or did I get some trash and hope everything is fine.
Old 04-19-2007, 06:28 PM
smokindog's Avatar
Do you mean P0216??? Or really P0261???
Old 04-19-2007, 06:32 PM
darrenw's Avatar
Sorry, You are correct, 0216. I guess one to many.Thanks.
Old 04-19-2007, 07:04 PM
darrenw's Avatar
Is this bad or a one time deal.
Old 04-19-2007, 07:12 PM
YJim's Avatar
Time for a new VP44...
Old 04-19-2007, 08:02 PM
PChouinard's Avatar
There's a ton of posts with the so called death code of po216. I've had the code for a while since I replaced my Lp. My truck runs like a champ to this day with the code. I would start saving for a Vp but I wouldn't get one right away. Run bio if you can get it. It works better in the Vp than ULSD in my opinion...
Old 04-19-2007, 08:17 PM
1-5-3-6-2-4's Avatar
i ran 10 months on a P0216 before it got really bad. start saving for a pump though.
Old 04-19-2007, 08:19 PM
ib516's Avatar
Exclamation
Hang on a sec. It may be the Superchips tuning that did it. I had the exact same thing happen (same symptoms, same code), when towing in hot/warm weather with the Superchips "tow safe" program installed. I returned to stock - no problem. Then I added an Edge EZ - still no problem. That was about a year ago, still on the same VP44 injection pump.
Before you go rushing in to getting a new pump, ditch the SC, and go stock for a while. If it still does it, you need a new IP. If it doesn't, get an EZ.
Old 04-23-2007, 06:45 PM
darrenw's Avatar
Thanks, I did take the SC out and I am running stock now. It has a little miss when starting cold but everything else seems fine. Sorry I didn't say thanks sooner other things came up.
Old 04-23-2007, 11:41 PM
Ph4tty's Avatar
Symptoms of a dying vp44 include dead pedal, mileage going south, and hard warm startups.
