P0236 Code
Old Sep 15, 2006 | 10:28 AM
scottsjeeprolet's Avatar
P0236 Code
I scaned my truck and found this code. Turbo boost sensor circuit.
I think and hope it is because my MAP is unplugged. Someone tell me it is so and not something more serious.
thanks
Old Sep 15, 2006 | 10:31 AM
getblown5.9's Avatar
yep, map sensor unplugged. no big deal.
when i ran my truck around with the comp harness installed and no comp...i couldnt figure out the low power problem. i had a code for low map sensor voltage which made me think of the comp no being there to boost fool.
PS- scott, you wanna come to mason-dixon pull at the end of the month?
Old Sep 15, 2006 | 11:08 AM
kantdrive55's Avatar
DTR Advertiser
I believe that is going to be a hard code as well that that will require a scanner to clear it from memory.
Old Sep 15, 2006 | 11:53 AM
[QUOTE=PS- scott, you wanna come to mason-dixon pull at the end of the month?[/QUOTE]
I have to check my schedule. Did you post this in the events forum? Might get more people to go.
Mudinyeri
Apr 4, 2011 09:34 AM
badmegacab
Feb 5, 2007 10:16 PM
badmegacab
Feb 5, 2007 09:53 PM
JyRO
Feb 17, 2006 08:06 AM
wadel1
Dec 6, 2005 05:30 PM
