P0191 code
Old Jan 18, 2009 | 07:42 PM
rbox's Avatar
P0191 code
Dash showed P 0191 code, could this be from a clogged fuel filter? I just changed the filter and the truck seems to run better.
Old Jan 19, 2009 | 09:14 PM
07ram's Avatar
code p0191
That code is for the Fuel Rail Pressure Sensor Performance. Don't know if the filter change will effect it or not. Good luck, Don
Old Jun 19, 2009 | 06:00 PM
unbob's Avatar
I've too have the P0191 code on my 2005 3500 CTD - now what?
Should I install a new fuel filter first, before taking to the shop for further daignosis. Engine runs great - no problems.
Thx, Rob
Old Jun 19, 2009 | 09:02 PM
CD in NM's Avatar
P0191 goes to rail pressure, rail pressure relief valve. They can momentarily stick open, loss of fuel pressure, throws code, then the valve closes and all is fine, no stalling when it happens unless you are sitting idling. Then things can run good for a while. I had the code 3 times in the first 2 months when my truck was new, finally the dealership replaced the valve, never had the code again.
CD
Old Jun 19, 2009 | 09:05 PM
BigIron70's Avatar
Cummins Guru
May just need a reflash, or retrofit transfer pump installed.
TSB 18-022-07 Flash: 5.9L turbo-Diesel Engine System Enhancements
Improvement to the Fuel Pressure Rationality Test to prevent possible false test
failures and the following related Diagnostic Trouble Code:
a. DTC P0191 - Fuel Rail Pressure Sensor Circuit Performance (2004.5 to 2005
vehicles)
Old Jun 20, 2009 | 05:54 PM
unbob's Avatar
Thanks for the replies!
Guess I'll contact a dealer service dept. and have it checked out.
tomm
Dec 21, 2016 09:23 PM
runamuk
Dec 21, 2016 09:05 PM
Crankpot
Aug 1, 2008 10:39 PM
MegaDawg
Jun 1, 2007 05:59 PM
ptgarcia
Jan 15, 2007 08:46 PM
