p00069 code Help!!
Old Feb 26, 2005 | 08:41 PM
wildbillnc's Avatar
Question p00069 code Help!!
Help I have a p00069 code showing and engine light is on what does this mean ther are no numbers in front of the 69 except the zeros
Old Feb 27, 2005 | 06:59 AM
wildbillnc's Avatar
I take it that no one has seen this before
Old Feb 27, 2005 | 07:40 AM
FarmerJim's Avatar
The code is "MAP/BARO Correlation" but I do not know what that means or what to do about it. Sorry I can not be of more help.
Old Feb 27, 2005 | 08:33 AM
v8440's Avatar
I'm gonna hazard a semi-educated guess here and say that there are two pressure-sensing devices: The map sensor, which measures pressure inside the intake tract, and the barometric sensor, which measures ambient pressure. That this code is saying is that there's a discrepancy between the two sensors. This would indicate that perhaps one of them is bad.
Old Feb 27, 2005 | 10:31 AM
nickleinonen's Avatar
i got myself a p0107 on friday... i suspect the map sensor let go... as i get a bad stumble now at 1900-2000 rpm under load and the ecm defuels bigtime after that point... was fine in the morning on the drive home from work, went to go to the bank later [like 2 hours] and went to merge with traffic [had to get on it hard cause it was a small gap i pulled into] and stumbled... oh well, to the dealer i go later this week... 1st failure for me..
Old Feb 27, 2005 | 12:30 PM
wildbillnc's Avatar
I think the map sensor might not have been connected good but not sure is there any way to clear the codes to see if they come back P0069,P2269 and a P0562 and the engine light stays on I forgot to mention that I disconected both batteries fo an hour but codes are still there also Auto Zone said they could not clear them just tell me what they are??
Old Feb 27, 2005 | 10:04 PM
D.O.A's Avatar
Just drive it, after a few good trips it will go out on its own....
coope3
Feb 21, 2009 04:49 PM
O.T
Sep 6, 2007 06:10 PM
dieselpower04
Aug 14, 2006 09:48 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
