p-pump to VE conversion
Old Feb 4, 2005 | 09:09 AM
RedRotors's Avatar
Im sure nobody has done this, but im just curious to know if the bolt
pattern of the P-pump is the same as the VE one ? Or for a conversion
like this you need to change the bracket that hold the pump..
I have a project on the corner of my table and i need those infos before
going further.
Marc/
Old Feb 4, 2005 | 09:24 AM
banks twinram's Avatar
the ve, is that the earlier models like the 89-93's if so, then i think you have to change out the aluminum front cover. the cam is a pain to get out of there, i recommend removing the rocker boxes-pushrods and turning the engine upside down before removing cam, if you have to go this route, then just so you won't be alarmed, there is only one cam bearing in the engines. i get the ve and vp mixed up... i know the later model computer pumps on 24 valve 2nd gens. are interchangeable, the bolt pattern that holds the pump to the aluminum case is the same
Old Feb 4, 2005 | 09:32 AM
RedRotors's Avatar
Hmm in that case, i think that i will machine an adapter plate instead of tearing
the engine down to change the aluminuim case.. You were right, i was ref. to the
old 89,93 rotary pump..
Thanks for the infos..
Marc/
Old Feb 4, 2005 | 03:53 PM
CTD NUT's Avatar
Do I understand this right?..........You want to swap in a VE in place of a P7100?!?!.........Why?
Old Feb 4, 2005 | 11:10 PM
Holsteinman's Avatar
I would like to know why also. The VE is a good pump, but I would never want to replace a P7100 with one.
Old Feb 4, 2005 | 11:17 PM
Forrest Nearing's Avatar
he yanked the good pump off a 2nd gen and wants to throw it on ebay to get some cash out of it
Old Feb 6, 2005 | 02:30 PM
RedRotors's Avatar
Nah.. I don't want to send my pump on ebay, don't worry.. I have a very good knowledge on VE pump and i might be able to get custom bigger head/plunger. I want to stay mechanical for now until a finish my custom ECU. After that i want to throw an electronic pump ( not a vp44 , but a VE37 ) in it.. So i'll be able to 'tune' the fueling and timing with custom maps of my own... For me, VE is a lot more easy to play with and more flexible than the P7100..
Marc/
Old Feb 11, 2010 | 11:38 AM
JD730's Avatar
Marc/
Who is going to make the custom hub or gear so the gear meshes with the cam gear?
It's probably easier to pull the cam out slightly and pull the gear off, then pull the cover and replace it with the one you need. Then put the gear back on. But for the effort, it might be easier to swap a VE powered engine right in place of the one you have now.
Old Feb 11, 2010 | 12:10 PM
BigErksG2's Avatar
I bet the project is in the past... posts are from 2005.
jimbo486
May 8, 2016 06:07 PM
6 2 Carl
Nov 27, 2010 09:55 AM
wcialrlter
Apr 17, 2008 05:51 PM
Jason Starnes
Aug 9, 2003 08:53 AM
Agades
Jun 23, 2003 04:30 PM
