P 1693 code
Old May 16, 2004 | 05:19 PM
Gene007's Avatar
P 1693 code
Could someone explain a little to me about this code (P1693). In the code list it says -- DTC Diagnostic Trouble Code: Fault code set by control module when sensor data is not as expected-- Could this be anything serious? Thanks
Gene007
WarWagon
Old May 16, 2004 | 05:55 PM
phox_mulder's Avatar
It's just a companion code.
Codes are thrown in a variety of computer modules.
Engine Control Module, Primary Control Module, Body Control Module, Transmission Control Module, etc.
The key on/off/on/off/on method only sees the ECM and PCM though,
and even then, not all the codes.
When a code is present in one of the modules, the 1693 is thrown in either the ECM or PCM, to tell you there is a code present somewhere in the system.
phox
high country
Dec 20, 2005 06:02 PM
Ritler
Feb 3, 2005 04:28 PM
LarryJ
Oct 10, 2004 09:35 AM
j
Mar 9, 2004 11:45 AM
roadrat
Jan 18, 2004 03:07 PM
