overhead comp
There is another thread going on now that is discussing if the wiring is in for that. I think some trucks have it in and not used, and others are not wired. Not sure if has something to do with the trim level or option packages.
I added one to my '02 and the harness was not there. Pull your console down and check the connector. The standard console has a 3 pin connector while the computer console has a 12 pin connector. In my case I got the computer/display, cable and temp sensor from a wrecking yard. I also picked up the autodimming mirror and lighted sunvisors since the donar truck had them. The wiring and connector under the dash were there and all I had to do was plug the console harness into them.
H8GAS
18
08-03-2007 06:31 PM
