overdrive going out
Old 09-04-2003, 07:50 AM
powerstroke's Avatar
overdrive going out
NEED HELP,
I have a 03 2500 larmine with auto. trans. and for the second time I lost my overdrive.Has anyone out there have or had any problem with a defective module in the computer.
Old 09-04-2003, 10:42 AM
cumminsho2500's Avatar
Re:overdrive going out
go to the dodge dealer then ???.....................no one else has had this problem
Old 09-04-2003, 10:50 AM
what trans do you have? if you post what your truck has on the bottom where mine is...its much easier to respond....just trying to help
Old 09-04-2003, 11:01 AM
from what i read check your grounds and crank shaft position sensor...thats what i read up on with the older models....could maybe be the same with the new models
Old 09-04-2003, 01:52 PM
Bertram65's Avatar
I had the same problem with my truck it is a large connector, it just had to be reseated. There was a discussion either here or TDR about it. I think someone mentioned it was a 60 pin connector but I am not sure, the dealer fixed mine.
Mikestowing
18
03-28-2010 08:07 PM
DIESELWRKS
07-29-2009 06:06 PM
CTD2001
08-24-2007 08:03 PM
72demon440
04-27-2007 10:45 PM
fitzydog
04-07-2005 03:44 PM
Quick Reply: overdrive going out
