Over charging problems still
Old 11-07-2010, 11:48 PM
cliffhanger1227's Avatar
After having over charging problems on my 91 dodge diesel I replace the voltage regulator with a new one......... Running a voltage check on the battery the voltage is going up and down from 12 to 15 volts back and fourth.
Is there anything else that could be causing this or do you think the new voltage regulator just might not be working properly........I could sure use some help on this, Thanks
Old 11-08-2010, 12:14 AM
SmokemS's Avatar
i'm having the same problem with mine.....i grounded the voltage reg to the block it helped when i was drving it but it does it at an idle....i think it is my alt not sure though
Diesel-Dan
20
09-22-2019 09:34 PM
whosdunit
12-30-2013 08:32 PM
Chipappa
10-02-2006 08:24 PM
boiler-rat
11-23-2004 10:52 PM
bigfoot
08-14-2004 02:22 PM
Quick Reply: Over charging problems still
