Open Diff from Factory
Old 10-07-2005, 10:26 AM
SkyHarborCowboy's Avatar
What options do I have to put in a Locking Diff on my 3500. If none, what is the best option?
Thanks,
Joe
Old 10-07-2005, 10:47 AM
Baja's Avatar
Check out reiderracing.com. They have a lot of pretty good information about different brands of diffs and their applications. Good luck.
Old 10-07-2005, 11:01 PM
akrammit's Avatar
There isn't a locker for the rear yet as far as I know. I believe Eaton and arb make one for the front. or you can get the one that is in the power wagon for the front.
Old 10-08-2005, 10:23 AM
Baja's Avatar
If your axle is Dana 80, Detroit makes a locker, but it is automatic, and I think ARB has one too. I settled for the Dana power loc, and if you rearrange the clutch pack, you can make it very aggressive. I can lift three wheels off the ground, and the one remaining wheel will pull the truck off the blocks.
Old 10-08-2005, 11:10 AM
nickleinonen's Avatar
no more dana's on 3rd gen's. all now are AAM...
Old 10-08-2005, 11:20 AM
Baja's Avatar
That is what I thought, so included the big "if". Thanks.
Old 10-08-2005, 12:56 PM
hauliday's Avatar
gov loc
tha amm axle takes a govloc you can get it for randys ring and pinion the carrier with bearings was about $582 just priced one for my 3500 cause i had a bearing go out @ 85k miles they use koyo bearings i opted to use timkin bearings it took a little while to cross them over but i think they will be worth it in the long run b.t.w the amm carrier is not serviceable so if something goes wrong with it you will have to be the whole thing
Old 10-08-2005, 07:36 PM
BigBlueDodge's Avatar
There's not much you can do right now. You can order the AAM limited slip from Randy's and put it in your self (Dealer quoted me $1200-1500 to put it in). There is no locker available today, but I'm told ARB is working on one as we speak. They only thing you can do is sit tight and play the waiting game.
Old 10-10-2005, 10:14 AM
1sttruck's Avatar
The Dodge 'Power Wagon' (?) has lockers front and rear. Although it has a 10.5 in rear it does have the same 9.25in front axle so you could look into putting a selectable locker up front. You wouldn't want to use it for heavy loads but it should work very well otherwise as our trucks are very nose heavy.
cowboykilla235
45
08-07-2015 07:19 AM
nate_88
07-19-2009 06:20 PM
Desert Diesel
03-18-2007 08:53 PM
sqrl$$
16
01-06-2007 05:28 PM
djp9747
19
10-02-2004 09:55 AM
Quick Reply: Open Diff from Factory
