old RV trailer ?
Old 09-30-2009, 09:30 PM
jferg711's Avatar
old RV trailer ?
Dad had a 26 foot RV and a tree fell through it and now its gutted and just the floor and plumbing is on it. My question is will the frame be strong enough to hold a tractor if i strip it and make it into a gooseneck?
Old 09-30-2009, 11:43 PM
2500Ram's Avatar
Need way more info. What kind of trailer and what kind of tractor. What kind of frame is it, boxed, C channel, I beam, thickness.
Good luck.
Old 10-01-2009, 12:19 AM
jferg711's Avatar
Well the 5th wheel part it boxed but not sure about the under side. It was a 1999 5th wheel caint remeber the model. The tractor is an older model Zetor just used for shredding. If the tractor is a no go i was going to make it into a trailer that had a three hole dog box on it and could carry my 4wheeler, 8dozen decoys, and other unting equipment. Surely it would be able to carry this much weight.
Old 10-01-2009, 08:22 AM
nkennedy's Avatar
Look at the GVWR for the trailer. Weigh the trailer now, and that should answer your question.
Old 10-01-2009, 09:52 AM
BRUISER's Avatar
I have looked into this alot and most trailer from mid 90's on are not strong enough they used 1/8 tube or angle to build the main frame since it was sort of a unibody construction
the older 80 and early 90 used 1/4" wall 2x6 tube which is strong enough.
best bet it to look at frame and see what it is. if 1/8" no way.. woul need a lot of steel added to it to make it strong enough.. if 1/4" wall shoul dnot be a problem
Old 10-01-2009, 11:59 AM
12valve@heart's Avatar
Check the axle weight rating and compare that to the weight of the tractor as a starting point.
Dodgezilla
11-06-2011 04:13 AM
chariotdriver
10-18-2008 10:50 PM
pet05
06-14-2006 10:00 PM
04ctd
04-05-2005 11:59 AM
kandgo
12-28-2003 01:34 PM
Quick Reply: old RV trailer ?
