old mans truck wont start...
this forum has been a great help to me on my third gen, so i figured id give you second gen guys a look.
My dads truck, 02, 5spd, 2wd, 2 new batts' stripped truck. Wont start.
he lives a couple of hours away, so i,ve not had a chance to mess with it myself. But heres the symptoms...
It wont start! wont turn over, dead!
i had him browse the forum, and he came up with a couple things:
- jumping across the starter, it fires right up
-he read something about continuity across the ign switch, it was "bad" so he replaced the ign switch
-swapped the relays around under the hood (dont know if that is acceptable to diagnose the issue, but he was under the impression they are 4 the same, so swapping them should find the dud?)
still no start, apparently no codes
Any thoughts?
Any thoughts?
when the starter contacts were just about worn out on mine, I could turn the key on off on a couple of times and it would finally start. search this section for threads about starter contacts.
Sounds like a starter/contacts issue. Sometimes there will be an audible click when trying to start the engine if the contacts are worn or sometimes there will be none. Sometimes the contacts can be worn in such a way that the solenoid plunger will ground and cause the starter 20a fuse (located in the underhood fuse/relay box) to blow which will result in nothing happening. If that fuse is blown then those contacts are in need of replacement. Very east job but does require getting under the truck to pull out the starter. The contacts are available for about $25 at various vendors or possibly a diesel performance shop close to you.
Cummins Guru
If truck has manual trans most likely clutch switch is bad or became unpluged somehow. It's under the knee bolster where the clutch rod goes out thru the firewall. You can jump across the switch and it will start but make sure you are in neutral or steping on clutch because it is a safety feature to prevent starting in gear.
hmm. he has bypassed the cltch switch, if the starter contacts were the issue, would it still fire perfectly when jumping across the starter with a screw driver?
Cummins Guru
Clutch switch open would cause a no crank, check fuse #9 (inside cab left side dash pull the little cover if blown will also cause a no crank. Possible excessive current draw from starter solenoid then, shorted solenoid.
I am not sure you would have an energized solenoid though with out a working clutch pedal disconnect.
My next thought would be the ignition switch and related fuses and relays.
Dodgezilla
11-06-2011 04:13 AM
chariotdriver
10-18-2008 10:50 PM
RNX CTD
04-19-2007 06:29 PM
getblown5.9
06-18-2006 04:56 PM
