Oil Usage
Old 12-19-2006, 05:24 PM
Mike T.'s Avatar
Oil Usage
This is my first diesel truck and I'm curious if these trucks are prone to use just a little oil? I don't see any blue smoke when running and I don't have any leaks. I've checked the fluids and I don't see any mixing of oil and coolant. When I purchased the truck it was completly stock and wasn't abused.
Your thoughts?... Thanks
Old 12-19-2006, 06:06 PM
Ace
Ace's Avatar
Yep, crankcase blowby comes out a tube on the driver's side of the engine down by the oil pan. Normally not much, mine leaves a few drops on the garage floor every night, and the bottom of the transmission is pretty grimy from going down the road. I think I used about a half quart in the last 2,000 miles.
Old 12-19-2006, 06:17 PM
Mike T.'s Avatar
Thanks Ace, that makes me feel a lot better.
Old 12-19-2006, 06:41 PM
rustbucket's Avatar
Smile
My 93 has less than 200,000 miles,and uses less then a pint between service times,around 6,000 to 7,000 miles.
Old 12-19-2006, 09:59 PM
edwinsmith's Avatar
Received 1,037 Likes on 762 Posts
Mine gets about 19 MPG of diesel oil. Does that count?
Old 12-20-2006, 07:45 AM
Mike T.'s Avatar
By your response guys I'll just assume a little usage is normal
Old 12-20-2006, 07:58 AM
flashgordon's Avatar
215,000 and used no oil between oil changes(5,000 miles)
Old 12-20-2006, 08:56 AM
jw216's Avatar
198,000 miles, Have never added any oil between changes. 4000 t0 5000 mi.
Old 12-20-2006, 09:00 AM
timb's Avatar
I guess it all depends on the engine. Mine has allways used 2 quarts between changes.
Old 12-20-2006, 09:10 AM
Ace
Ace's Avatar
Yyyyyep. And just because you didn't add any doesn't mean it wasn't low!
But I'll assume everyone here is checking their oil level on a regular basis.
Old 12-20-2006, 06:17 PM
ChrisLib's Avatar
Mine has 182k on it and has used about 2qts per OCI. No blowby but the RMS has leaked since I got it. It recently has gone up to about 1qt. per 150 miles...RMS is shot...GRRR so the CTD gets parked till after the holdays.
Old 12-20-2006, 06:30 PM
Mine goes through around a quart between changes (6k).
RattlerSkin
20
04-08-2007 11:48 AM
pybyr
08-28-2006 06:33 PM
tfarmer96
03-23-2005 11:06 AM
JohnnyH
11-15-2004 09:21 AM
MR. GADGET
04-24-2003 02:51 PM
Quick Reply: Oil Usage
