oil presure
Old 08-15-2008, 06:30 PM
jkrauss's Avatar
oil presure
I have a 1998.5 dodge diesel at 2000 rpm what should my oil presure be, I use 15w40 oil
Old 08-15-2008, 08:22 PM
dozer12216's Avatar
Minimum of 30 psi.
Old 08-16-2008, 01:13 AM
Zeus1987's Avatar
with my truck i will never see under 40 psi cruising at 60 id say it is around 50-60 psi.
Old 08-17-2008, 09:11 AM
jkrauss's Avatar
thanks my oil preasure is at 70 psi at 70 mph and 2000 rpm i was wondering if this was high and what would cause high oil preasure (new used truck to me)
Old 08-17-2008, 08:44 PM
dozer12216's Avatar
Is this from a real gauge or dash gauge? Dash gauges and sending unit are subject to lots of varations.
Seventy is sort of high IMO. Would rather have 40 PSI or so. Less HP to maintain. On the other hand seventy is not bad. It just increases the oil churning around in the crankcase.
Old 08-19-2008, 08:05 AM
jkrauss's Avatar
yes its a dash gage. any idea's on a better set of gauges ,like to have one for fuel presure too.
Old 08-19-2008, 04:10 PM
Diesel Doc's Avatar
98.5 ran a higher oil pressure than newer engines for some reason. The guages are even different in the dash.
Old 08-19-2008, 04:19 PM
RowJ's Avatar
And Dodge changed sensors in 02....... more sensitive. Not just ok...too high.... too low!
Find someone with a real gauge ...added on... and you will hear about a lot higher pressures than the gauge shows. The member I talked to (an 01) said idle is around 60 psi and it cruises around 70-80 psi.
RJ
tig
01-31-2007 06:30 PM
tig
01-28-2007 11:46 PM
axe595
08-10-2005 09:17 PM
cincydiesel
05-21-2005 05:10 PM
Nitro71455
18
01-03-2004 12:17 AM
Quick Reply: oil presure
