Oil pressure!?!?!
Oil pressure!?!?!
Ok, so when i start my pickup the oil pressure light stays on for about 2 or 3 seconds and then shuts off and the gauge slowly climbs to operating pressure. I unhooked the line to the turbo and started the truck (having just cooked the he351 because of it) and saw no oil come out of the line for about the forst 3 seconds then it picked up just like the gauge did. My question is shouldnt this line have pressure as soon as the truck is started? And if it is a problem what do i need to do to fix it?
Thanks,
-Chris
Thanks,
-Chris
It's not going have oil instantly. It takes a few seconds as you found for the oil pump to pressurize the system. It has to fill the main oil rifle and reach all the main and rod bearings as well. If it's that much of a concern, maybe you could install a check valve in the oil supply line to the turbo, if there is such a thing out there for that.
GlennRMK
05-24-2007 10:46 PM
Power Ram 250 C
02-20-2007 11:08 AM
streetsmoker
02-22-2006 06:47 PM
bigragu
01-24-2006 11:16 AM
CIN'S DODGE
16
12-05-2005 04:14 PM
