Oil Pressure
Oil Pressure
Hey guys does dipricol make an oil pressure gauge? I am getting ready for a few minor changes. For those who are running them what kind of numbers do you see? Jay
DOn't know anything about dipricol.
My oil pressure runs at the following pressures:
Idle, HOT day, 200-210F Engine: 6-8psi
2500rpm, 200-210F Engine: 40-50psi
Cold start, hot day/cold day: >60psi
Winter Idle, hot engine: 10-12psi
Tony
Tony
If you are looking for a pressure range. I would recommend a 0-100 PSI gauge. I know on a cold start mine can pretty much peg that when the oil is thick. Once warmed up I run around 65 psi cruising on the interstate
Thanks guys, I guess I dont need an isolator. Where would you tap into the system? I will be running an amsoil bmk-25 remote setup to make room for the new addition(s) to the family Jay
GlennRMK
05-24-2007 10:46 PM
Power Ram 250 C
02-20-2007 11:08 AM
streetsmoker
02-22-2006 06:47 PM
bigragu
01-24-2006 11:16 AM
CIN'S DODGE
16
12-05-2005 04:14 PM
