oil pressure
oil pressure
so i was driving hom from work today and i get to a red light and my dash chimed at me so i looked at my gauges and my oil pressure said 0 so i hit the gas and it went up to 40 so i gave it an oil change and it hasnt done it again bot that was today. by the way my oil pressure has been running at 3/4 the way for the past 4 months and its still doing it after the oil change. any suggstions
I would not worry about it unless it happens again!
On your 99, O psi does not mean '0'. It means less than 8 psi +/- (working from memory).
Did you ck your oil level on the dip stick before changing it?
RJ
RJ
The 99 actually has a real oil pressure sensor. If the gauge is reading "O" then the sensor is going bad or there is another problem.
I have been experiencing a similiar issue.
Last Friday on my way home from work I stoped at a friend house for about an hour or so, (truck ran great, oil presure 3/4 range) on my way home I lost oil presure (according to my gauge) my "check gauge" light came on, so I pulled over, turned off the engine, checked my dipstick, checked for leakes etc. Oil level was good, no leaks to be found, so I fired it back up and my gauge was at 3/4 range so I drove home. So I drove all week and everything was fine until today, it did the same thing. I asumming that my oil pressure sending unit either has a bad connection or is taking a ****.
Are these sending units expensive or hard to change? It should just thread into the block right? Where is it located?
Easy to change. Just takes a 32mm deep well. The sensor is located on the fuel side of the engine down around the ecm towards the driver. It is usually a beige or black plastic with a brass bottom.
Thought the 98.5 thru 01 oil sensors/gauges were all basically 3 position....low, good and high. I know the 01 is. When did they make that change?
RJ
What should I expect to pay?
My truck read 0 psi the day after I bought it new. 7 years ago and over 70k. I started it the next day and everything was fine. The dealer could find nothing wrong. Hasn't had a problem since.
RJ
GlennRMK
05-24-2007 10:46 PM
Power Ram 250 C
02-20-2007 11:08 AM
streetsmoker
02-22-2006 06:47 PM
bigragu
01-24-2006 11:16 AM
CIN'S DODGE
16
12-05-2005 04:14 PM
