Oil Pressure Gage
Old 05-01-2007, 07:58 AM
genros's Avatar
Oil Pressure Gage
I have an open pod in one of my gage clusters. i have read about the value of knowing you have good oil pressure in the pan (cracked injectors leaking fuel in and so on) Is this a valid case? Does anyoen here run one ? If so where did you put the feed line for the gage and where did you get the gage. I run Dipricol gages now and would like to match the appearence.
Old 05-01-2007, 02:08 PM
genros's Avatar
bump, anyone?
Old 05-01-2007, 02:27 PM
dodgezilla04's Avatar
you could run the gauge off the oil filter housing, there is a 1/8" plug in the top.
Old 05-01-2007, 02:46 PM
tufamc's Avatar
Hi, I have a one in a overhead mount. I put the sender in the oil fliter housing, there are 2 1/8npt plugs on top, I used the one to the left as you are looking at it. I had to get a 45deg pice of pipe fron the hardware store to make it work, there is a collent pipe right above the housing that prevents you from just putting the sender in. My pressure is about 35-45psi cold idle, 13-18psi hot idle and about 45-50psi at anything above 1000rpm, also I'm running Shell Rottela T 5w-40 synthic. I got the gauages from Jeg's they are Autometer
Old 05-01-2007, 05:00 PM
genros's Avatar
Thank You for the help
Old 05-01-2007, 06:20 PM
Raspy's Avatar
[QUOTE=genros;1487087]I have an open pod in one of my gage clusters. i have read about the value of knowing you have good oil pressure in the pan (cracked injectors leaking fuel in and so on)
What do you mean by oil pressure in the pan?
Wetspirit
Old 05-02-2007, 01:25 AM
Desert Dually's Avatar
pan pressure?
[QUOTE=Wetspirit;1487968]
Wetspirit
yeah, i was wondering about that too, but was afraid to ask Thanks for doing it for me!
retiredguy
18
10-01-2011 05:23 PM
dwhite1957
10-19-2008 04:27 PM
heykw
10-15-2007 12:45 PM
SKINNERBOY
12-23-2006 09:19 PM
DBF
07-24-2006 05:53 AM
Quick Reply: Oil Pressure Gage
