Oil Leak.......
Old 03-24-2006, 06:01 PM
TJPro351's Avatar
Oil Leak.......
I have an oil leak coming from that "half moon" panel located on the front bottom of the transmission case. I looked above tranny and all around and still seems like it is coming from that plate. I would think it would be tranny fluid because of where it is coming from?? But I know it is oil. I tighten the 3 small screws but still have a slow leak. What is under that panel?? Why is it leaking oil there?
Thanks for your help.
TJ
Old 03-24-2006, 07:21 PM
Oilguy's Avatar
Take it back to the dealer... It is probably a rear main seal.
I don't see many do that.. but there have been a couple.
Oilguy
Old 03-24-2006, 07:32 PM
TJPro351's Avatar
I was afraid of that
Old 03-24-2006, 09:49 PM
djbikeman's Avatar
Oil from the breather tube tends to blow back onto the TC cover (that half moon cover you speak of) making it look like it is leaking. My 04.5 did it and my 06 does it. This is fairly normal. The breather tube is on the left side of the motor just in front of the tranny. I know my tranny has a film of oil on it now and a few drops build up occasionally. I just wipe them off when I change the oil. I have never had any oil on the garage floor from this.
Old 03-25-2006, 04:48 AM
TexasCTD's Avatar
Ditto on what he said.
Old 03-25-2006, 09:32 AM
TJPro351's Avatar
Brought the truck to the dealer this morning and when they removed the inspection plate on the Bell Housing, it was "wet" with oil. They wiped the oil and let run for about 30 minutes and it was slowly seaping. Rear Main Seal on order!!! Just my luck to have one of the very few with a bad rear main.
Old 03-26-2006, 02:45 PM
djbikeman's Avatar
Bummer. I was hoping, for your sake, it was just the breather tube.
george7941
11-28-2009 09:28 PM
6speedcowboy
01-14-2007 01:41 AM
Iron City
06-12-2006 02:37 PM
donhov
26
01-06-2006 07:29 PM
PCarnathan
08-15-2005 09:59 AM
Quick Reply: Oil Leak.......
