oil leak
oil leak
Hi, I have a 99 dodge diesel, I have an oil leak somewere by the power steering pump. It's leaking engine oil. Does anybody know what normally leaks on this. Is it the oil seal on the shaft the drives the steering pump or just a gasket bad. I just would like to know before i go rippen it apart so i have everything i need.
thanks
dan
thanks
dan
Re:oil leak
I also have a bad leak at the pump. From what I understand from threads, the seal on the vacumme pump shaft and the power steering pump goes bad. Do a search there are several threads on this site about it.
Lest we forget
Re:oil leak
Yours might not have a bottle, on my 02 it's on the left front end of the engine. Black plastic bottle with four holes in it near the top. So when it gets to full of rain water and blow by oil and comes out of the holes, the fan will blow it all over the left side of your engine. Very bad design I think. The engineers must have been drinking the day they thought of putting the bottle where it is. Their sure is room for improvement in that area. I taped my bottom two side holes shut so the fan would not pick up the blow by film so much.
Waam Holland, Mich
Waam Holland, Mich
Re:oil leak
Dan
Check out the other posts on this p/s vacuum pump leak,seal and o ring are available through Napa,part # are given in the threads,June 27,2003 ps leak,has all the info you will need,just had mine done on my 2000 CTD
Re:oil leak
[quote author=DRESSER DAVE link=board=4;threadid=22300;start=0#msg209652 date=1068832426]
Dan
[/quote]
How do you get the search engine to go back past September? Tried every key word I can think of and it always ends around September.
Dan
[/quote]
Re:oil leak
[quote author=dansdodgediesel link=board=4;threadid=22300;start=0#msg210249 date=1069015869]
I put a new seal in today. took about a hour and half. Hope it works out. Thanks for your help everybody.
Dan
[/quote]
I hope just the seal takes care of your oil leak. On mine, I had to replace the O-ring also to cure the leak. Sorry I didn't get to reply sooner to tell you about the O-ring. It's definately a "do it as long as you are in there item". Good Luck.
Dan
[/quote]
george7941
11-28-2009 09:28 PM
Iron City
06-12-2006 02:37 PM
donhov
26
01-06-2006 07:29 PM
PCarnathan
08-15-2005 09:59 AM
