oil on leading edge of fuel tank
Old 11-15-2010, 08:21 PM
SORTIE's Avatar
my mechanic has sealed up darn near every leak in my machine but every time I take a long trip, I see a bunch of oil drops on the leading edge of the fuel tank.
could it be oil leaking out of the Getrag? it's overfilled 1 1/2 quarts
Old 11-15-2010, 08:29 PM
93flatbed's Avatar
Road draft tube?
Wettstein's Avatar
my does the same thing, it is the out put seal on the t-case going to th rear axle. it wont leak juct sitting there and if you wash it you may miss it all together. if you wash off the back of the t-case and go for a little drive, and then get under it u may see a little oil behind the drive shaft yoke. or if it is like mine you will see drops of oil
hope this helps
Jim
Old 11-15-2010, 08:30 PM
Onemoparnut's Avatar
Could just be a little oil coming from the blow by tube. That is also on the left side of the engine.
Old 11-15-2010, 08:37 PM
Wettstein's Avatar
^^X2 on that one, forgot about that
Old 11-15-2010, 09:12 PM
NE frmhnd's Avatar
My rear main keeps everything well undercoated. Got a trans leak now, too.
Old 11-15-2010, 10:58 PM
92smokin blacky's Avatar
mine has the output seal on the t case leakin too.
Old 11-16-2010, 07:47 AM
Subliminal's Avatar
Chalk up another one for leaking transfer case output. Mine isn't a few drops, though...
Old 11-16-2010, 09:58 AM
unixcowboy's Avatar
I always thought that was the 'anti-corrosion' system that came with these trucks
Old 11-22-2010, 08:05 PM
SORTIE's Avatar
transfer case seal makes sense; it ain't diesel
we'll have to get after that one next; how involved is seal replacement?
Old 11-22-2010, 08:17 PM
TIMMY22's Avatar
Rear brake line runs between the fuel tank and frame. Sometimes they will drip before they give up the ghost.
Old 11-22-2010, 08:34 PM
1st gen wontabe's Avatar
That maybe well worth looking into!
Old 11-22-2010, 08:35 PM
Rampage1967's Avatar
It's an external lubrication system.
Old 11-22-2010, 09:56 PM
SORTIE's Avatar
nope, not brake lines
replaced all of the brake lines in my truck this summer...they WERE toast
Old 11-22-2010, 11:17 PM
schamran's Avatar
maybe it's not oil... check to see if it's grease from your u-joint? if it got wet with water (say a rainstorm) it might look a little more like oil. I dunno, just trying to help.
CascadeFirstGen
09-19-2013 08:38 AM
Beta
10-28-2011 10:26 PM
M Penwald
15
03-09-2011 06:23 PM
Stamey
06-27-2008 02:04 PM
dervolksfuhrer
01-31-2008 09:10 PM
Quick Reply: oil on leading edge of fuel tank
