oil in fuel
Old 07-27-2010, 08:04 PM
samaf's Avatar
oil in fuel
How much 2 stroke oil shoud you add per gallon of fuel? I do not remember reading this but I am oretty sure it has been addressed before.
Old 07-27-2010, 08:53 PM
jncornett's Avatar
consensus is 1 oz per gallon
Old 07-27-2010, 09:08 PM
Junk Man's Avatar
anyone got a measured change in lubricity or is this simply supposition?
Old 07-27-2010, 09:27 PM
b4wheeler's Avatar
I usually put about 8oz in a tank full. It makes a marked difference in the injector noise...Much quieter........
Old 07-27-2010, 09:49 PM
BigGreen's Avatar
Going to have to try it.
Old 07-30-2010, 08:21 PM
jncornett's Avatar
there used to be one i had it on my pc... its gone i cleaned aout alot of info i had saved after i sold my common rail a year ago... i know mopar1973man has done alot of research on the subject with a lot of miles to back it up... Jump on his site and look around and ask that question there and i bet you get the answers you want... www.mopar1973man.com
Old 07-30-2010, 08:42 PM
Junk Man's Avatar
Interesting site. He thinks things through & seems pretty accurate. You still need to be careful of those that run off at the mouth & only repeat what they've read (who knows where).
Old 07-30-2010, 11:03 PM
WestTN's Avatar
I never use any. No problems in 153,00+ miles.
Old 07-31-2010, 07:23 AM
jncornett's Avatar
I also ran it in my 05 for 3 years it was noticably quieter and i gained 1 mpg...Now on the 24 valve, not so much i didnt see any mpg change at all but the engine was a little happier (quieter) I stopped using it simply because no mpg gain for extra cost.I needed the extra money elswhere with the tranny and converter slipping..
I really wish I hadnt deleted that test info it covered all or most of the fuel addatives and showed a break down and which ones worked best to least and the 2 stroke was at the top of the list. And if I recall correctly Marval Mystery oil was 2nd or 3rd on the list.
I thought i found it on the net last night but the links dont work anymore..
Junkman I agree with you on people repeating different things read or heard...It always takes me a while to jump on any band wagon I want proof! test research, pictures of injectors after use for a year or more etc.......
Old 07-31-2010, 08:11 AM
Ace
Ace's Avatar
I suppose if you add lubricant lubricity increases.
Old 07-31-2010, 08:51 PM
Junk Man's Avatar
The question is how much improvement in lubricity. I've read where ULSD is supposed to have additives put in before it gets put into the station tank. Apparently, sometimes it gets enough, sometimes not which results in crappy non-lubricating fuel which damages expensive equipment. There are comparisons between the old diesel that these trucks were meant to run on & ULSD. Some studies conclude that certain additives decrease lubricity. All this to say that you can't just grab some "additive" or oil or grease and As s/u/me that it will help enough to keep the VP going.
It is perfectly ok if you choose to use anything or nothing. It is your truck. Do as you choose. ULSD has caused problems and to question various options is valid.
Old 07-31-2010, 10:24 PM
davemac's Avatar
Maybe this`ll help. I use Super Tech, 1 oz per gallon which is a ratio of 1/132. The chart lists 1/200.
Old 07-31-2010, 11:01 PM
nickg's Avatar
here is the entire thread, it was done over on the GM forum, I cant say I've seen any mileage increase, but it if you listen closely to your engine (near the VP) it will sound noisy and you can almost "see" the noise, run 2 stroke for 10mins and that noise dissappears
http://www.dieselplace.com/forum/sho...d.php?t=177728
Old 08-01-2010, 07:34 AM
Ace
Ace's Avatar
And British Petroleum was "supposed" to be following certain safety protocols on the Deepwater Horizon...
Old 08-01-2010, 10:31 AM
jncornett's Avatar
great info guys... although this is not the same list i had saved it is still very close to what i remember except for the opti lube...And for what ever reason i remember the marval oil being rated better but im prolly wrong on that ive slept a few times since 2005
Quick Reply: oil in fuel
