Oil Drain Plug - OEM or Aftermarket?
Old 04-26-2007, 11:41 PM
BAJA MAN's Avatar
I am getting ready to start doing my own oil changes. I read on genos that the OEM drain plugs can become brittle and crack, as the flush mount design leaves little shoulder on bolt.
Genos offers different replacement options:
1. brass drain plug that appears heavy duty and uses a hex head bolt head- not oem flush mount style with square head sunken in
2. quick drain valves/plugs). The replacement drain plug looks pretty beefy.
CONCERNS:
1. How secure/safe are these replacements (vibrating loose, strip threads,
not flush mount, etc.)?
2. Possibility of someone messing around and crawling under truck and
draing oil (with drain valve style)
Should I keep my OEM or replace?
Thanks!
Old 04-27-2007, 11:00 AM
jkitterman's Avatar
OEM is fine, just don't overtorque.
Old 04-27-2007, 11:35 AM
DUKFVR's Avatar
The plugs with the valves sure make it easy & no mess to change your oil. Have had them on 5 different trucks & no problems.
Old 04-27-2007, 01:26 PM
Arkapigdiesel's Avatar
Go Fumoto. Have 'em on every single vehicle I own and have ever owned.
Old 04-27-2007, 01:33 PM
ptgarcia's Avatar
I put quick drain valve from Genos on mine the last time I changed the oil. I haven't used the valve to drain the oil yet but no issues with leaking or anything else. Its definately a well made product.
Old 04-27-2007, 06:54 PM
stezlaki's Avatar
I have a fumoto and like it. No leaks or problems so far. Makes oil changes quicker/easier and cleaner!
Old 04-28-2007, 12:22 AM
labreck's Avatar
a valve hanging down would catch mud and brantches when your in 4 mheel drive, it would happen to me that is. flat mount plug for me
Old 04-28-2007, 08:07 AM
eswartz's Avatar
Just replaced my stock drain plug with the Geno's EZ Drain Plug 2 days ago, I haven't drained oil from it yet. I just like the idea of no mess oil changes. The $52 price is a bit high.
I have used afumoto on previous vehicles, I just didn't like the idea of it hanging down from the pan. I have never read of one breaking, but with my luck I'd be the first.
Old 04-28-2007, 09:17 AM
harleysnguns's Avatar
I picked up the heavy duty one, from Genos, you spoke of.
I figure it will sit in the parts bin until/if I think the stock one looks like it may fail. Course, I also go by the owners manual for plug torque 37ft-lbs.
Old 04-29-2007, 01:04 PM
nriver's Avatar
ez drain plug. No issues with it hanging down and catching stuff.
Old 04-30-2007, 06:51 AM
LongRanger's Avatar
I got the Geno's heavy duty. I didn't want to worry about the standard plug cracking, although I'm sure it holds up find most of the time, and I like the idea of the magnet on the Geno's plug.
Old 04-30-2007, 07:13 AM
ShaneCTD600's Avatar
Just ordered the Fumoto from Geno's. We'll see.
TPilaske
08-28-2004 10:25 AM
Sonny
04-29-2004 11:48 AM
blafleur
06-16-2003 05:45 PM
apc
02-28-2003 08:47 AM
m batterson
02-19-2003 10:03 PM
Quick Reply: Oil Drain Plug - OEM or Aftermarket?
