Oil dipstick not accurate
Old 06-02-2008, 07:25 AM
Valv's Avatar
My dipstick is not quite accurate as measurement.
I can top oil to max, and after 1000 miles it burns it down to 1/2 way safe area, where is stays forever.
I can drive 10,000 miles and it does not use any oil if I leave it at 1/2 safe level, if I top it to to max, I will burn it until down to 1/2 again.
I guess that's why they call it "safe" area, not Max and Min.
Old 06-02-2008, 10:36 AM
2003Ram's Avatar
Not sure about your dipstick, but what I can tell you is it takes 12 quarts. One in the filter and the rest in the hole. I don't even check the dipstick.
Old 06-02-2008, 10:41 AM
Jason Foster's Avatar
If you run too much oil, it can damage your engine just as much a running to little. Keep it in the safe zone and check it every so often. Cheap insurance compared with the cost of repairs.
Old 06-02-2008, 02:10 PM
Roperteacher's Avatar
I have an 07 5.9 and it is CRITICAL that you ck it on a LEVEL surface!! Iven with 15 pounds of air in my airbags will shift it 1/2 qyart or so on the stick. My 2002 never moves regardless if it is flat or KINDA flat! LOLOL
Old 06-02-2008, 03:00 PM
dozer12216's Avatar
Have similiar issue and use 12 qt fill up. Seems to use less or throw out less at low end of safe range. Probablly will go with 10 qt fill and check more frequentlly, just keeping in safe range.
Old 06-02-2008, 03:05 PM
motrapper's Avatar
yes my 07 is the same way acouple of degrees angle and it shifts 1qt the 05 10 degrees hardly any change thats just weird
Old 06-02-2008, 03:08 PM
trik396's Avatar
Very true...
I don't think you're burning it off if it's going from full to 1/2 on the dipstick. I think it's getting blow out of the crankcase without you knowing it. I fill mine to the top of the hash mark every oil change and after awhile it lowers itself to the middle every time and stays there... I consider this normal for my truck now...
Our trucks are like women... they all behave a little differently and have diverse personalities, but we love them anyway...
Old 06-02-2008, 09:35 PM
Valv's Avatar
Originally Posted by trik396
Very true...
That's exactly like mine.
I said "burn it off' but it actually runs it through the vent, since I always have a nice light oil coating underneath.
I claim my truck frame will never rust...
1985cucv
15
04-17-2009 09:06 AM
dss667
05-01-2004 11:59 AM
PapaPerk
04-28-2004 08:30 PM
The_Warden
10-26-2003 07:51 AM
misterKTM
03-02-2003 07:06 PM
Quick Reply: Oil dipstick not accurate
