Oil Analysis with 15W40 Supertech oil at 194k miles
Just got my oil tested from 4,000 miles of HARD miles.. about 8 sled pull hooks and daily driving with high EGT runs.
This was using Wal-Mart SuperTech 15W40 motor oil and a FRAM filter..
I had a BHAF installed the whole time.
Here are the results:
Spectrochemical Analysis *PPM*
Iron: 42
Chromium: 2
Lead: 0
Copper: 3
Tin: 0
Aluminum: 6
Nickel: 0
Silver: 0
Silicon: 16
Boron: 5
Sodium: 12
Magnesium: 17
Calcium: 2732??
Barium: 0
Phosphorus: 1051?
Zinc: 1289?
Molybenum: 7
Titanium: 0
Vanadium: 0
Potassium: 0
Physical Properties
Fuel: % Volume: N/A
Vis @40C N/A
Vis @100C: 13.72
Water % by volume: 0
Soot Solids: 2.1% by weight
Glycol: NEG
I talked to the guy who ran the testing.
The only thing he commented on was the soot-solids
Any comments? How does this look for an engine with 194k?
Iron: 42
Chromium: 2
Lead: 0
Copper: 3
Tin: 0
Aluminum: 6
Nickel: 0
Silver: 0
Silicon: 16
Boron: 5
Sodium: 12
Magnesium: 17
Calcium: 2732??
Barium: 0
Phosphorus: 1051?
Zinc: 1289?
Molybenum: 7
Titanium: 0
Vanadium: 0
Potassium: 0
Physical Properties
Fuel: % Volume: N/A
Vis @40C N/A
Vis @100C: 13.72
Glycol: NEG
Is 16 high for Silicon?
I'm guessing your in the minority with those choices of filter and lube. I recently switched over to Fleetguard from FRAM after reading the horror stories. Still use them on my other cars though,
I know a lot of people bash WalMart oil so I figured I'd have it tested before I switched to Conklin oil.
Originally Posted by Bobcat698
He said everything look normal, the only thing that was out of spec by a little bit was the soot content.
The 16 silicon is high, I like to see under 5ppm.
Silicon usually comes though the air intake but just opening the engine up for a valve adjustment or any other type of work can raise the level no matter how clean you try to be. Just minute amount of dirt/dust getting in the sample can jack it up it also.
I've always learned to pick one brand of oil and stick with it. That's why I wouldn't use SuperTech. Apparently like all Walmart products they go for the cheapest source and you could be getting a different brand with every oil change.
extremeshot
10-04-2010 12:13 PM
snowmanx
02-23-2010 11:28 PM
bluebull
15
05-09-2005 08:35 PM
bluebull
17
05-09-2005 07:47 PM
