Oh NO !! Accidentally pushed in a plug in the ECU that I need to fill with new wire
Old Mar 26, 2005 | 08:14 PM
IH8MYCAT's Avatar
I can't believe I did it. I accidentally pushed in the stupid little red plug in the ECU that I need to put a new wire in for my new Pacbrake.
Is there a way to get it out ???
I'd like to ask you guys before I do anything else to it.
Once I do get it out, and ready to put the new wire in, How much insulation should I strip off the wire end to put in the hole as bare wire ??
Old Mar 26, 2005 | 08:32 PM
pind's Avatar
hey man, nothing to it.
make sure your batteries are unhooked, and carefully remove the connector from the ecm, then use a very small welding tip cleaner, or piece of tag wire to push the plug back out through the hole. I have had to do this a couple of times with ornery plugs.
Remember, don't sweat the petty things, and whatever you do.... don't pet the sweaty things.
Good luck, and happy braking
Old Mar 26, 2005 | 09:13 PM
IH8MYCAT's Avatar
Thanks !!!
Whats the proper way to put a new wire in there ??
Old Mar 26, 2005 | 09:48 PM
pind's Avatar
the wire that comes with the pacbrake should have the pin already on the end of it. you merely push it into place from the outside, after you re-attach the connector to the ECM. Viola, goes together like two rabbits.
when you are properly hooked up, with the wire in the proper terminal on the connector block, you will notice what Pac calls a 3 second delay, between letting off the throttle, and engagement of the brake. This delay can actually vary between 1 and 3 seconds, although I have yet to see more than a 3 second delay. Makes life so much easier. No goofing about with microswitches for the throttle and clutch pedals, quick easy install, clean, professional.
If you have any issues, or are running in cold weather, PM me. I am currently testing some cold weather solutions for PacBrake. I will say this, their warranty support thus far, has been second to none. A lot of large corporations could learn many valuable things from them.
Old Mar 27, 2005 | 09:59 AM
John Faughn's Avatar
I can'nt tell from your post do you have a connector that is specificaly for that use , I've been getting computer connectors also the crimper made just for these from napa , then there is also some tools for removing the metal connector from the plastic pugs so you do'nt mangle either.
sharp21
Jul 2, 2009 11:10 AM
tmacie
Jan 16, 2006 07:02 PM
PapaPerk
Nov 29, 2004 09:13 PM
TPilaske
16
Nov 22, 2002 08:15 PM
