How often do you change your fuel filter?
Old 09-12-2011, 08:16 AM
Crallscars's Avatar
I had a 1992 12V I changed the oil every 5k and I had to change that little filer every 10k or I would be found on the side of the road changing it.
My 2001 24V I change the oil at 10k, I have been running the fuel filters 25k+ or so and never had one clog. Actually forgot when I change my last one, so it's due now.
I am just afraid to run them too long and starve the VP. Your thoughts?
Old 09-12-2011, 08:54 AM
nkennedy's Avatar
Every other oil change, so about 10K miles.
Habiodun Bliczm (03-24-2021)
Old 09-12-2011, 09:04 AM
Dieseldude4x4's Avatar
75,000 to 80,000 miles.
Old 09-12-2011, 01:01 PM
nothingbutdarts's Avatar
Originally Posted by nkennedy
every other oil change, so about 10k miles.
xx2
Old 09-12-2011, 01:04 PM
Redrammer99's Avatar
X3
Old 09-12-2011, 01:05 PM
BRO
BRO's Avatar
I have 100K on my truck and I changed mine out twice since I purchased it new. On both occasions, I think the filters looked fine. Plus if you have a fuel pressure gage you can tell if you flow is becoming restrictive. Unless you hang out in Mexico, I would not worry about to much.
Old 09-12-2011, 05:13 PM
Silver R/T's Avatar
Living in NW mine is usually pretty clean
Old 09-13-2011, 12:43 PM
01RAMer's Avatar
Whenever the fuel pressure at idle starts to drop.
Old 09-13-2011, 01:02 PM
Crallscars's Avatar
I dont want to have to put a gauge in the cab, if i were to add one it would be trans temp. I just want the truck to be reliable,
Old 09-13-2011, 01:56 PM
Midnite's Avatar
A fuel pressure gauge is one of the more important gauges to have on a 24 valve 2nd gen truck like you have. This is because of the fuel pressure sensitivity of the VP44 injection pump as well as the stock lift pump being prone to failure.
Reliability is my #1 concern as well, and in my truck I added three gauges: fuel pressure, boost, and EGT (exhaust gas temp). They all have their purpose and they're all very important to me. Transmission temp is also great to have on a truck with an auto. I have a manual transmission, but if I had an auto I'd have a tranny temp gauge too.
Old 09-16-2011, 11:56 AM
joem's Avatar
Depends on the fuel. around here I change mine every 20k and its super clean. If I fueled from a rusty farm tank id change it every 5k
Old 09-16-2011, 12:01 PM
Matt127's Avatar
i change my oil ever 5k and fuel filter every other oil change
Crallscars
07-03-2015 12:37 PM
505diesel
24
08-02-2006 09:33 AM
drew03
21
09-19-2005 05:46 PM
coobie
13
03-16-2004 06:55 AM
93w250
12-31-2002 08:50 PM
Quick Reply: How often do you change your fuel filter?
