odd turbo sound
Old 01-21-2008, 12:18 PM
idacal's Avatar
odd turbo sound
the stock turbo in my 96 makes a fluttering wooshing sound when it shifts into overdrive sounds like its coming out of the intake is it tearing something up or is that normal ? thanks for the help with this
Old 01-21-2008, 01:32 PM
haloman's Avatar
Its called "barking the turbo". Its a stall of the shaft while its shifting.
Old 01-21-2008, 02:58 PM
kyachovitz's Avatar
I believe that's the turbo bark. When the engine is creating a lot of boost, and suddenly the demand for that much air to the engine isn't needed, the air - instead of being pushed into the engine - actually "backflows" into the turbo for a moment. The woosh sound is just air hitting the turbo from the "wrong" side.
Most will say this is somewhat normal and won't cause any harm. I don't think you have anything to worry about.
Old 01-21-2008, 06:03 PM
somis13's Avatar
A.K.A. compressor surge. it can cause the compressor wheel blades to bend. I've seen it happen to a some turbos
Old 01-21-2008, 08:55 PM
idacal's Avatar
how can a person fix it? right now i just let off the pedal before it shifts but when other people drive it I can hear it barking as you call it over the sound of exhaust from 400 yards away
Old 01-21-2008, 09:01 PM
mhuppertz's Avatar
It can also snap the turbo shaft.
Old 01-21-2008, 10:09 PM
cstroup's Avatar
Mine does the same thing. Been doing it for quiet a while.
Old 01-22-2008, 09:53 AM
king5335's Avatar
I am kinda ignorent to this issue, but is the turbo bark sound kind of like hearing something like a bad sound like something grinding, my truck here recently I went round a corner and matted her and didn't have a lot of room so had to let off quickly( I now know better than to do that from what you guys are saying it is very bad on the turbo ) and the turbo made a nasty weird sound like the wheel was hitting the side or something but I have checked my slop in the shaft and it can't hit the side just very litttle slop, any help would help thanks
Old 01-22-2008, 10:11 AM
fordkiller43's Avatar
My turbo barks whenever I let off the throttle suddenly. I wouldnt suggest drivin around town or wherever and purposely doin it all the time just for the sound. If it just happens very now and then you will be fine. If its an ongoing thing constantly happening it could do damage. Mine has never barked while the trans shifts into overdrive tho....
Old 01-22-2008, 10:18 AM
king5335's Avatar
yeah i am guessing that mine is just turbo bark I was scared it was about to go south, but i can get it to do it when I hit it hard and then let off quick, but if I keep into it at bout 30psi it doesn't do it so that makes me feel a little better......cool I hope
Old 01-22-2008, 10:20 AM
Yeah king you should be straight man. Mines the same way when Im around 30 psi as well. Do you have a j hook installed on youre truck?
Old 01-22-2008, 11:27 AM
king5335's Avatar
yeah I have the j-hook on the turbo, but when i put it in, it didn't make a whole lot of change think I strecthed the spring out when installing it, so I just grabbed my stiffest dirtbike pipe spring and threw that on there too.
95twotone
04-05-2010 09:22 PM
matt_w_fluitt@y
08-20-2008 02:14 PM
dhughe2
01-26-2007 04:24 PM
BigBlue
17
03-28-2006 02:47 PM
Journier
17
06-26-2004 09:51 AM
Quick Reply: odd turbo sound
